headlight not illuminating
Old Apr 30, 2007 | 01:34 PM
Shaymer's Avatar
88 pickup
Had a blown driver's side headlight. Switched it out with a new one. The new one worked when I checked it. Didn't work that night. Tried switching bulbs and passanger side bulb didn't work either, but the driver's side worked in the passanger side.... So thought it was a fuse or connection. But why would the old bulb not work, a new one work briefly, then not work either.
-checked fuses, all seem fine unless there's one I don't see.
-Seems like a loose connection problem, rather than a major electrical problem.
Any tips or advice would be appriciated.
Thanks,
Shamus
Old May 3, 2007 | 06:10 AM
Blair's Avatar
Check that you have a good connector. My driver side low beam was out, but the high beam worked.When I reversed the connection, the low beam worked, the high didn't. Turned out it was a corroded wire, inside the connector. Just replaced the connector, no troubles.
kawazx636
Oct 6, 2021 03:03 PM
4banginRunner
Nov 13, 2015 05:23 AM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
