Headgaskets Replaced, now crank no start.
Old Dec 16, 2019 | 03:51 PM
Kadin Cook's Avatar
I couldnt find a thread with a solution to my issue. If you know of one feel free to point me to it and Ill delete this one.
Anyway, ive got a 1995 toyota 4runner 3.0. I just did headgaskets, i took pictures and marked everything i could as far as timing goes. Ive triple checked that it is identica to how it was when i disassembled it. Now it cranks but has no intention on firing, it also has a “back fire” could be coming from the intake. Now im at a loss, no codes either. That to me screams timing but i have it set exactly as it was and it ran when i pulled it in the shop. Thanks in advance.
Old Dec 16, 2019 | 05:47 PM
dbittle's Avatar
I would start by checking the wiring connectors, that it has spark, and that the distributor is timed correctly.
Old Dec 17, 2019 | 06:17 AM
Kadin Cook's Avatar
see thats where I messed up was i wasnt thinking and pulled the distributor out. So isnt it just set the engine to tdc compression stroke and make sure the rotor is pointed at #1?
Old Dec 17, 2019 | 01:34 PM
Andy A's Avatar
Motor at TDC and line up distributor as follows for insertion
https://www.yotatech.com/forums/f116...l#post52331873
Old Dec 17, 2019 | 05:59 PM
dbittle's Avatar
If the distributor is right, are the plug wires going to the correct cylinders? Throw a timing light on #1, crank it and make sure you have spark.
ChrisWilhelmArt
Nov 3, 2017 11:59 AM
19Turbo86
Aug 18, 2017 01:40 PM
Chart23
May 8, 2017 05:38 PM
elohman
Jun 30, 2008 07:51 PM
utah 4runner
Jul 21, 2007 01:36 PM
