Head Gasket Woes...Again
Old Jul 10, 2010 | 08:44 PM
  #121
ChefYota4x4's Avatar
WOW, Lumpy, you were not messing around! You know what? THAT PIC with your Grampa putting in the oil? PRICELESS! That is frameable, in my book! lol.
Awesome, Lumpy...what else can I say, aside from YOU ROCK! haha
Old Jul 13, 2010 | 09:18 AM
  #122
Lumpy's Avatar
Ok ran out to the bank on Monday during lunch and the battery light was on...so I didn't shut it off. On my way back to the office I shut it down and it wouldn't start do I popped the clutch and it was alright. Tach was bouncing all over the place.
After work it started and ran just fine, no light either. Half way home the battery light came on so I drove to Advanced Auto (the battery is old, how old I donno) they said I had a bad cell. Replaced the battery and same thing. Battery light on and bouncy tach. I think I have a bad ground somewhere. Will look into it this evening some if I have time.
Other than that she runs great!!!
Old Jul 13, 2010 | 09:25 AM
  #123
Dang, that's 3 ELECTRICAL ISSUES in a few days! ..... Must be a 'Gremlin Conspiracy', haha.
Glad it's running great, Lumpy!
Old Jul 13, 2010 | 12:12 PM
  #124
92 TOY's Avatar
LUMPY....if i recall correctly it was 3 grounds to check.
drivers side rear of head
alternator
lower intake at area of #3
Old Jul 13, 2010 | 01:14 PM
  #125
yotarob2005's Avatar
nice work Lumpy, that was definatlly faster than most.
Old Jul 13, 2010 | 01:49 PM
  #126
Lumpy's Avatar
Thanks guys...What I think I need to do is run a ground from the battery to the old ground where the battery was. I have the new ground going to the head by ways of the P/S pump mount but that may not be enough. I also am going to check the ground on the alt and the plugs on the alt.
Old Jul 13, 2010 | 02:40 PM
  #127
Lumpy's Avatar
Ok, I added an additional ground and had it with the alt ground. Cleaned them up and the light was still on. Check the voltage running and it was 12.5 so off to Advanced Auto I went. Had them check it and the alt never showed up during the test. Love the life time warranty. I should have it in a few days. I just don't have time to mess with it for a few weeks.
O well at least I know it was not me or something I did or didn't do. Bad battery and bad alt.
Old Jul 13, 2010 | 02:57 PM
  #128
92 TOY's Avatar
ouch LUMPY.....you are having a bad stretch of luck lately.......but some god fortune too.....i guess it kinda evens out a little
Old Jul 13, 2010 | 03:31 PM
  #129
DANG, .....glad you got it solved though! Looking forward to a 'bleeder drive by', soon! hahaha.
Old Jul 26, 2010 | 08:07 AM
  #130
Lumpy's Avatar
Ok changed out the alt and all is well!!! Drove to work today and round a bit yesterday seems to be holding tight and all is dry.
As I said before, I'm not going to bother with the dyno but my "seat-of-pants" says it's got more pull now. So 268 cam + 2.25 exhaust - cat + Street RV head = More go.
Old Jul 26, 2010 | 09:47 AM
  #131
Sweet! ............. BLEEDER DRIVE BY WITH BRODIE! LOL. jkjkjk.. .Break it in a bit first, lol.
Old Jul 30, 2010 | 10:18 AM
  #132
Lumpy's Avatar
Drive by coming soon...
Well after fueling up on a full tank I have good news as long as my math is correct. Before the new head and running the 268 cam I was getting about 17mpg and that's with compensating 8% for the 31's on 4.10's. Now with the new R/V head I got almost 21mpg using the 8% for the tires.
Even if my 8% is a bit off I'm still getting better mileage than I was before the rebuild. So that makes me a happy camper!!!
Old Jul 30, 2010 | 10:33 AM
  #133
21 city???????
Old Jul 30, 2010 | 01:30 PM
  #134
pruney81's Avatar
I get 20 city but that's just with 4.10's and 235/75/15 Costco AT's
Old Aug 2, 2010 | 07:20 AM
  #135
Lumpy's Avatar
It's mixed driving...I'll be getting fuel tonight so I can get a better idea of my average.
Old Aug 2, 2010 | 11:07 AM
  #136
Gotcha! I figured out I'm getting around 17-city, LOTS of stop and go(you know, the 'SEA OF RED' you've heard of when people refer to L.A.???, hahaha).
I'm going to fill up at a frwy onramp and try her out again to see......haven't done ANY FRWY other than that one test drive, weeks ago(Was nice though, ...having her do 90-and wanting more ).
Look forward to your results and REALLY happy for you that you're not having any issues, Lumpy! ROCK ON! lol.
Old Sep 14, 2010 | 10:16 AM
  #137
Lumpy's Avatar
Well I have almost 3K on her now and I have a bit of an issue that has slowly gotten worse. I'm thinking its a timing thing like it's not advancing when is should. Some days it'll be just fine and others its a bit sluggish like I'm towing something. You give it gas and it just doesn't getup and go as it should. Other days it takes off. Does the same hot/cold/dry/wet/day/night/empty tank/full tank. Sometimes it's fine then while your accelerating it falls on its' face and becomes sluggish. I don't think is vacuum related but not ruling that out.
Also the tach will bounce only while accelerating. Just holding speed it does not bounce.
Gotta wait till the weekend to mess with it.
My thoughts are that the pickup inside the dizzy may need cleaned. All connections seem to be tight and I have checked all grounds and added and additional ground.
Can one of you guys send me some good pictures of your vacuum connections at the rear of the motor where the EGR stuff is. I want to be sure I have the FPL and EGR stuff routed correctly. I may have a vac line or 3 switched around. So Pics of the back of the vac rail will really help out.
Still getting about 20+ mpg mixed driving so that's a plus. Can't wait to see how it does after I get this ironed out.
Old Sep 14, 2010 | 10:38 AM
  #138
92 TOY's Avatar
hey.....gimme a text.
i can easily take pics of anything you need.
3000 miles already???? where the hell do you go?? i just turned over 3000 and i'm over a month ahead of you.
you had those issues with the gas line in the winter.......chance of being similar???
Old Sep 14, 2010 | 10:57 AM
  #139
xxxtreme22r's Avatar
jesus, I only got like 6500 on mine and I've been done since october. lol
Old Sep 14, 2010 | 10:59 AM
  #140
I can get you some pics Lumpy. Will try to remember to take them tonight & post them in the AM.
BTW, my Tacoma has 57K in 5 years.
