Head Gasket Woes...Again
Old Feb 2, 2011 | 12:51 PM
  #261
92 TOY's Avatar
Originally Posted by Lumpy
I did use a straight edge and light to check them.
Iron City "Light" does not count. Just sayin'
Old Feb 2, 2011 | 12:57 PM
  #262
Lumpy's Avatar
Dolt!
Old Feb 2, 2011 | 01:00 PM
  #263
92 TOY's Avatar
I found it. that's right by you. that rocks.
Old Feb 2, 2011 | 10:31 PM
  #264
ChefYota4x4's Avatar
Alrighty, I was a bit ill the past few days so the couch was mine...
Now this is what I found...
1. intake gasket looked not quite right. May have leaked a bit.
2. Head g/s on 4 was looking rough, I think it came apart. Small mark on cylinder wall. Enough that you can see it but not feel it. More like a burn mark. I know it was not there on last build.
3. Check block seems flat enough, checked head seemed flat enough. Doesn't seem warped or anything.
I started on it a little after 10 am and finished up about 8 with a hour lunch break. I had Dad helping till 3 and my buddy Bob till 1. Bob was there for the tear down and cleaning we were ready to reassemble by 1:00. Dad helped me get the head on and valves adjusted. From there I was on me own.
Thanks XXX, 92 and Chef for the help on the vacuum lines. Now that I have those in the right places it seems to be doing very well.
WOOT! LOL......... wanna come do mine now? hahaha. Jk
Old Feb 3, 2011 | 01:22 PM
  #265
Lumpy's Avatar
You pay for the flight I'll bring the Iron!!!
Old Feb 3, 2011 | 01:51 PM
  #266
Hahahaha! Man, I wish. I could probably fly everyone down if I hadn't been so messed over in the last year! lol.
Old Feb 3, 2011 | 07:17 PM
  #267
bigtrucknwheels's Avatar
man I miss having internet... I really hope this pans out for you Lumpy! I also hope I have my 89 going by summer's end so I can finally meet all you guys up at Rausch lol
Old Mar 16, 2011 | 02:59 PM
  #268
Lumpy's Avatar
Ok update...
the 180 stat I had started to...well stick I suppose. It warm up to about where the 190 used to be then it would drop down right above the fat line for C. It would normally run just off the line.
So I decided to get the normal stat again. When I pulled the old one it had a slight film on it. Not sure what it was. So I tossed in the new one and let it warm up a bit then went for a ride. It went straight to 12 o-clock which is a bit high for this stat and stayed there.
I left it idle for 3-5 min checked the hoses they were cool to the touch. Both the top and bottom were cool. The thermostat housing was warm and the bottom of it was hot.
Went for another ride and the stat opened up (I guess) and the temp went to where it always was about 11 o-clock.
What gives here...didn't matter if the heater was all hot or all cold. Do I have a plug somewhere??? It blew hot air and both lines going to and from the heater coil were hot like they should.
My concern is that it started doing this a while back and that's when it decided to over heat and pop when the H/G.
Old Mar 16, 2011 | 03:15 PM
  #269
xxxtreme22r's Avatar
How's your radiator and fan clutch? You can hear the fan clutch turn on and off when it is started cold right?
Old Mar 16, 2011 | 03:29 PM
  #270
Lumpy's Avatar
The clutch seems fine. It doesn't over heat it just heats up then all of a sudden it cools. As it was idling the fan was not spinning above normal. Both the top and bottom hoses were cool very cool but the needle was straight up and down and the heater hoses were very hot.
Rad is 2 years old and the cap is 3 months old.
Old Mar 16, 2011 | 03:35 PM
  #271
Lawman65's Avatar
Is it possible there is air bubbles in the coolant system?
Old Mar 16, 2011 | 03:37 PM
  #272
Lumpy's Avatar
It could be but unlikely. It's been burped and burped.
It idles fine doesn't surge. I guess I can try burping again on a steeper hill.
Old Mar 16, 2011 | 04:35 PM
  #273
92 TOY's Avatar
hmmmm.
you said there was film on it. what does that mean? like slime? if it's not gonna get cold enough to freeze in the near future, i would say flush it as good as you can, fill up with water, driver around, drain / flush, lather, rinse repeat. i know this from experience that i could never truly empty or flush the system totally, so i had to basically dilute it down until i was just getting water out in the end. then i used toyota gold, errr i mean RED coolant.
i also have the 2-stage thermostat.
Old Mar 16, 2011 | 04:48 PM
  #274
Lumpy's Avatar
I'm using a red coolant from Advanced Auto their brand. As long as you have a clean system coolant is coolant. You cannot mix different coolants though.
It was a film looked like rust at first but it wiped right off. Maybe I'll have to try your thing and then park on a big hill and refill it.
Old Mar 16, 2011 | 05:04 PM
  #275
Lumpy's Avatar
http://www.4crawler.com/4x4/CheapTri...tatReplacement
Old Jul 21, 2011 | 11:45 AM
  #276
Lumpy's Avatar
Ok time for an update!!!
She's running well no issue. Getting about 23mpg
Doin my happy dance!!!
Old Jul 22, 2011 | 10:57 AM
  #277
THAT'S IT? hahahaha. JK, but hey, why not pics very often of that beast? I know, there were some at the 4 wheeling events, .... but c'mon, give us a vid or a couple pics, eh? hahaha.
HAPPY FOR YA! AND, ......23MPG?...................................wan ker, grrr! hahahaa.
Old Jul 22, 2011 | 11:57 AM
  #278
Lumpy's Avatar
I'll get some vids this weekend. I have been taking a few runs here and there but not in the truck. I take the 4Runner for that stuff. The truck is my DD and I need a truck.
Old Jul 22, 2011 | 08:48 PM
  #279
GOTCHA
You enjoy it, bud!
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
themightykhoner
Aug 11, 2015 07:37 PM
Coreyr384
Jul 10, 2015 11:13 AM
