Hard to start 22r please any help would be appreciated
Old Oct 10, 2014 | 06:54 AM
Eliska's Avatar
I know this is a much asked question. I work away from home a month at a time, so my 1987 Toyota pickup 2x4 sits till I return. It absolutely will not start without a very small shot of starting fluid in the breather. I just installed a NEW carburetor. Once it's starts it's fine as long as I don't let it sit more than 7-8 days. Truck runs smooth and strong.
Old Oct 10, 2014 | 11:31 PM
wyoming9's Avatar
Red face
Seems to be the Nature of gas these days.
It tends to evaporate while sitting for long periods of time .
or the fuel drains back to the tank when sitting that long.
Then the mechanical pump takes quite a while to get fuel to the carb.
Spray a shot of starting fluid to get it running your good to go.
Is the fuel pump helping make the issue worse who can say.
Don`t know how much a problem this is or what you want to do to fix it.
Just a thought a electric pump made for the psi of the Carb turn the key your fuel system is pressurized .
You may have other issues as well.
If you can live with a shot of starting fluid when you get home live with it.
JF9243176
Oct 8, 2017 04:21 AM
bigblue82
10
Jul 6, 2015 08:27 AM
serenity03k64
Jun 27, 2015 07:59 AM
JF9243176
Jun 24, 2015 04:53 AM
jmc88runner
Jun 18, 2015 03:39 PM
