Hard to shift into first gear from nuetral
Old Sep 8, 2006 | 10:40 AM
BC Rider's Avatar
Originally Posted by geoduke
I have this problem also. If it is the pilot bearing, is it bad to force the stick into gear?
It is generally bad to force a tranny into gear. The reason you are forcing it (ie. bad pilot, bad pressure plate, incorrect pedal adjustment, etc.) doesn't really matter.
How bad is it? Unfortunatelly only time can tell. You could screw up your tranny syncros, linkage etc.
You may find that you can use less force if you put it into 4th, then quickly move into first.
Old Jan 8, 2015 | 03:10 AM
sabine's Avatar
shredded shift seat
shift seating in bits. cheap and easy fix see video link below.
Old Jan 8, 2015 | 06:54 AM
bswarm's Avatar
If you end up replacing the clutch, get dealer parts. I've had to redo many clutch jobs because the shop manager kept getting cheap aftermarket clutch kits. I finally refused to do them unless they got dealer parts and never had any more problems.
Old Jul 18, 2015 | 03:22 AM
sabine's Avatar
MorphiasX
You were right and here is a video which helped me change it.
Old Jul 18, 2015 | 05:27 PM
  #25
Odin's Avatar
I've seen that video before but I'm still confused why he messed with the pins?
Anybody???
Old Sep 3, 2018 | 09:11 PM
  #26
Toocool4school's Avatar
Pilot Bearing or Shift Seat
BC Rider,
I am having the same exact issue with my r150f tranny.
Did you ever resolve the issue? I know this was 12 years ago
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
Tykiller1994
Aug 10, 2015 07:49 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Jnkml
Jul 6, 2015 01:20 PM
