HArd to get into gear
Old Oct 28, 2017 | 10:55 AM
88_1stgenner's Avatar
I have a 1988 Toyota 4runner sr5 3.0 5spd, I replaced the clutch about 5,000 miles ago. There was a weird shaking when releasing the clutch in first gear but it shifted fine. Now it is hard to Get into all gears but the pedal is still firm. I bled both the master and the slave and the pedal only had a better feel to it, could I have messed up the throwout? any advice will help. I'm in a hurry because it's getting cold in WI
Old Oct 28, 2017 | 11:19 AM
gsp4life's Avatar
Is the clutch pedal linkage adjusted properly? The steps are pretty simple and found in a Haynes or Chilton's.​​​​​ Also, do you know what type of gear oil's in the tranny and t-case? If too heavy weight, it'll be noticeably harder to shift during cold weather. What type of clutch did you install? A clutch meant for rock crawling can cause chatter on a stock rig.
Old Oct 28, 2017 | 11:22 AM
scope103's Avatar
https://www.yotatech.com/forums/f116...fatigue-32667/
Old Oct 28, 2017 | 11:26 AM
gsp4life's Avatar
+1 forgot about that simple, common failure.
Old Oct 28, 2017 | 12:24 PM
I tried adjusting the pedal but I can only find the push rod adjustment. I'm going to keep looking but I think I'm going to just drop the tranny today.
wrenchtech
50
Sep 8, 2019 01:18 AM
SodiumFlouride
Feb 6, 2018 07:40 AM
snugent
Jan 13, 2018 10:31 AM
Andythomasday
Nov 29, 2017 10:55 PM
smithra1979
Nov 24, 2017 08:03 PM
