hanger bearing or 4runner driveshaft?
Old Apr 16, 2010 | 08:26 PM
toyotanick's Avatar
my hanger bearing is destroyed! easily a half inch of play in any direction and fo some reason the parts store cant get it. through toyota its a 300dollar part and that just seams rediculous for a danm bearing so i was thinking about just doing away with this crappy idea and going with the 4runner shaft. some knowledgeable opinions would be great! thanks guys
Old Apr 17, 2010 | 07:55 AM
yayfortrees's Avatar
I would look for a hanger bearing or driveshaft off of a used truck. Where are you located? Is it for that xtra cab in your avatar? Is that 4WD?
I would start with local junk yards, or try and find a parts truck. I might have one off a 2WD soon, but I don't know the condition of it.
Good luck!
Old Apr 17, 2010 | 07:19 PM
toyotanick's Avatar
it is a 4wd and yes it is my avatar. the solid driveshaft off of a 4runner with the same body style will work right? if so i will go get it tomorrow! along with 63inch chevy's for the rear!
Old Apr 17, 2010 | 09:04 PM
I'm really not sure if that will fit or not. I wonder why the trucks run the 2 piece driveshaft, and the runner uses a 1 piece?
Anybody know about this? Is it for clearance? Pinion angle? 'Cuz they wanted to? I have wondered about this before.
Old Apr 18, 2010 | 06:42 PM
toyotanick's Avatar
anyone? i need a little help guys
Old Apr 20, 2010 | 02:34 PM
Wheelingnoob's Avatar
The 4runner shaft will not work, its about 20" to short, they are a 106" wheel base the Extracab PU is 121"
If you want a one piece you will have to get one made.
Old Apr 20, 2010 | 03:15 PM
anthony1's Avatar
2nd what Wheelingnoob said...Most driveline shop can even use yours and cut off what every they don't need to make it a one piece.
They also balanced it for you. When you get it back, if you want to take it apart, mark it first or you'll have to get it re-balance.
Old Apr 20, 2010 | 04:14 PM
allnmstkn313's Avatar
It's two piece for clearance only. Just junkyard one, they're ungodly expensive new.
For the effort of actually making/having one made, just buy a new support...
Old Apr 20, 2010 | 04:17 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Send a PM to Death Cougar, he works at Nix99, a Toyota/Lexus wrecking yard.....he might have 1, and/or get you 1....
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
Gamble_STi
Jul 7, 2015 07:54 PM
