Grinding noise front driver side wheel 91 pickup
Old Sep 16, 2022 | 10:42 AM
Chase Forman's Avatar
Hello everyone I've recently been getting intermittent grinding on my front wheel I replaced caliper and brakes/rotors with no change I took the locking hub off the front today and found this gold metal material shown in pictures below but can't locate where it could be coming from anyone expirence this before? It doesn't feel like the wheel bearings out but it's hard to see.
Old Sep 17, 2022 | 03:29 AM
Andy A's Avatar
If gold in color most likely what is called the steering knuckle bushings. There are 2 per side, inner and outer. The outer half shaft end rides in them. With that much wear the wheels bearing should also be replaced. They don't look to good in picture.
Old Sep 17, 2022 | 04:46 AM
Andy A's Avatar
Big is the inner little one is the outer
Old Sep 17, 2022 | 05:56 AM
scope103's Avatar
I don't know if AndyA is right (sounds like he is), but here's a drawing that shows the location of those bushings. http://web.archive.org/web/201102060...15componen.pdf
short21yang
May 21, 2020 04:35 PM
mertz
Dec 8, 2010 02:22 PM
Slowstrike
Oct 13, 2008 02:05 PM
AK4x4
Oct 11, 2008 06:18 AM
PatHLC128
Oct 7, 2006 07:58 PM
