grinding into reverse
Old Jul 24, 2008 | 12:36 PM
TomkiRider's Avatar
sp ive had this problem a while and its just drivin me insane! whenever i go to shift into reverse, as im goin down theres a grinding of gears, no im NOT moving and rpms are NOT up. it weird, sometimes it does it and sometimes it doesnt. anyone?
Old Jul 24, 2008 | 12:37 PM
904_runner's Avatar
Going to reverse sometimes sucks
MIne will do that once in a while. I usually push the clutch twice and it won't do it, or you might try going into first then reverse.
Old Jul 24, 2008 | 12:42 PM
Jay351's Avatar
Put it in 1st or 2nd before you put it in reverse. Works everytime...
Old Jul 24, 2008 | 12:47 PM
TomkiRider's Avatar
k thanks ill try that for sure. as i was puttin my new battery in i noticed this stray wire
<a href="http://s296.photobucket.com/albums/mm188/TomkiRider/?action=view&current=yotawire.jpg" target="_blank"><img src="http://i296.photobucket.com/albums/mm188/TomkiRider/yotawire.jpg" border="0" alt="Photobucket"></a>
anyone know what this is? if ya need to know where its comin from ill go take a pic im not good at explainin
Old Jul 24, 2008 | 12:48 PM
Jay351's Avatar
Looks like the AC plug to me..
Old Jul 24, 2008 | 12:52 PM
TomkiRider's Avatar
HUH! maybe thats why my AC doesnt work for lol! i ahve no idea where it goes, could u direct me in the right direction?
Old Jul 24, 2008 | 01:00 PM
Jay351's Avatar
It should plug straight into the compressor. It plugs in from the top. Hard to explain. Easy to find. Its the only wire that goes to the compressor.
Old Jul 24, 2008 | 01:37 PM
MSR's Avatar
MSR
Tomki you might also need a shifter bushing the r150's eat oe bushings I stock marlins hardened bushings instead of toyota
Old Jul 24, 2008 | 03:37 PM
Jay351's Avatar
Thats true, I had replaced mine with the marlin unit. It fixed alot of problems, but not the grinding in reverse. Alot of yota's I have driven had this problem... Just wear and tear I suppose..
Old Jul 24, 2008 | 03:54 PM
abecedarian's Avatar
and change the fluid in the trans. some grinding issues are caused by old fluid in the gearbox.
Old Jul 24, 2008 | 03:55 PM
and how do you figure you've had this problem a while?
You've only had the truck a month or so...
j/k
Old Jul 24, 2008 | 06:16 PM
TomkiRider's Avatar
yep goin into 1st before reverse solves it 100%
Old Jul 26, 2008 | 06:53 PM
just a 22re's Avatar
mine grinds then jumps and the tyres bark maybe i should stop going into rev at 35mph?
ok thats was a funny my bad
i go 4th then rev works all the time plus its a stick shift any older car or truck in the world is going to do this unless it has a new or rebuilt trany its just the way they are lol
Old Jul 26, 2008 | 06:57 PM
algranger's Avatar
bleed your line and adjust your clutch i had the same problem and that fixed it for me
Old Jul 26, 2008 | 07:05 PM
jason191918's Avatar
You have to wait for the input shaft to slow down before you can put it in reverse. If you are stopped, the output is stopped, but if the clutch is in, the input just spins for a lil bit before slowing down. Something that might help is to take the clutch out halfway when shifting into reverse.
irv
Oct 1, 2015 09:49 PM
scheuvront1993
Sep 17, 2015 06:17 PM
langry345
Sep 14, 2015 03:36 PM
May-39
Sep 6, 2015 01:05 PM
Nick Berg
Sep 3, 2015 04:36 AM
