Got some BJ spacers for $60
Ideally, you want to keep unsprung weight down on a vehicle- that's to say that you wan as little possible weight that's not attached rigidly to the frame. This is important for ride quality... I'll explain why if you like, or you can google.
#25
i got the procomp es1000's, got em on a ebay deals for like 80 bucks for the set. i think they're good for the money but for sure not the best. they do ride a lil rough but i just got use to it.
#26
my google fingers are lazy today
#27
Quote from the Wiki on "unsprung mass": Unsprung weight includes the mass of components such as the wheel axles, wheel bearings, tires, and a portion of the weight of driveshafts, springs, shock absorbers, and suspension links. If the vehicle's brakes are mounted outboard (i.e., within the wheel), their weight is also part of the unsprung weight.
So if you go from the stock 26 inch tires to 35" tires you just added like 25 pounds of unsprung mass to each corner of your truck. So??? It's gonna burst into flames right??? Haha. Obviously your "unsprung mass" argument is pointless and ill-founded. If you were an engineer I would listen to you. They're simple spacers, that's all. They're made of steel like ALL of the other suspension components on a Yota. Theyre not gonna cause any issues what-so-ever and I only paid $60 for them ahahaa.
#30
lol
that would be a big hunk of aluminum!
yeah I don't have to worry about rust too much here in Fl, as far as salting the roads being the main cause. as long as you stay off the beach, you're fine, lol
the rust is an easy thing to prevent IMO; the fact that they are 3 separate peices stacked together is what I would worry about the most
if it were me, I would definately look into putting a good weld at the joints of them, all the way around
maybe bolt them together so they're in line (before installing them), and run a good solid weld ALL THE WAY AROUND each mating line between the layers, and you should be fine
then prime them, paint them, bolt them on, and you should be good to go (after an alignment of coarse)
#31
#32
These seem pretty sketchy to me. Definitely want to weld them up.
me too, AND they came with the 8 mounting bolts + nuts (maybe $20 from the hardware store?), AND we didn't have to modify them to make them work (welder + time + paint = more money). Sounds like your $60 steel BJ spacers just bumped up to the price of aluminum SDORI BJ spacers.
#34
Bolts, nuts, washers(GRADE 8)cost me 8 bucks. Not gonna weld them up. Why should I? It will make no difference if I do or don't. Paint, wow, .15 cents worth of paint, hope I can afford that..... I promise they're not going to rust just because they're made of steel. Aluminum oxidizes also just FYI.
#36
It's your truck, so of course you are entitled to do what you want. I'm curious as to how this will work out, so definitely post a write-up.
I'm also curious as to why you are giving so much attitude. The point of this site is to get in touch with other toyota owners who can share knowledge and constructive feedback. But it seems that you're not very receptive towards anyone's ideas...
#38
okay enough arguing about welding and rusting... just bolt 'em on, and be the first to try them out
find out the pros and cons, and share with the Yotatech community
you've already bought them, you're going to do whatever you want to do, so to drag this out is pointless
I for one hope they work out great for you
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
4runnerFireman
Sep 29, 2015 06:24 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
Sep 27, 2015 07:15 AM
