Which gears do i need?
Old Nov 23, 2020 | 03:21 PM
Chuckspadina's Avatar
Hi there,
I am new to the yoda fam!
I just purchased a 1988 yoda sr5. It has been setup and used for off road, but I'm converting for on and off road use as it is my daily driver. It is currently set up with 5.29 gears, and a 5” lift kit and a 3” body lift.
I want it to drive smoothly on the express way. Currently in 5th gear it vibrates so much. I assume if i geared it down i would gain some speed along with reduce the vibrations? Also it came with 35” mid tires, but they were shot. I switched to a 31” all terrain tire.
Old Nov 23, 2020 | 03:30 PM
wallytoo's Avatar
the gears are not likely to be causing vibration. look at the tires, driveshaft, alignment, steering parts (tie rods, etc), wheel bearings.
you went to nh to buy it?
Old Nov 23, 2020 | 08:21 PM
muddpigg's Avatar
Check out 4crawler.com should be in drive train chapter. Look for driveline101 link. It talks of different style joints and operating angles and angle of flanges. Of course check for any looseness also.
5.29s with 31s has gotta be over geared. Bet it pulls hills awesome. Are you measuring speed by speedo or GPS?
Old Nov 23, 2020 | 09:11 PM
cracked's Avatar
was thinking the same thing when I read that..
Old Nov 28, 2020 | 06:12 AM
Dr Phat's Avatar
4.10 is stock I believe but like others said the vibration is most likely being caused by something else, I would guess the driveshafts or tires, or a combination of both.
Old Nov 28, 2020 | 07:43 AM
swampedout's Avatar
5 Year Member
You also know that truck has been axle swapped if its an 88. Plus the big lift. Theres lots of places to start looking for driveline vibrations.
For gears: https://www.roundforge.com/articles/...ules_of_Thumb_
Cool truck btw! Looks like someone already put a lot of work into it.
Old Nov 30, 2020 | 11:50 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Wallytoo's post hits the point. My bet would be on the tires. I can't tell you how many times Toyota truck owners with offroad tires would come in talking about vibrations, but wouldn't even consider the tires. I'd go grab another truck and swap out the rims and tires just to shorten the conversation.
Old Nov 30, 2020 | 02:53 PM
wallytoo's Avatar
i'd stop offering any advice/opinions in this thread until the OP actually responds. 1 post total, nothing so far after the comments.
motodude95
39
Sep 30, 2021 06:08 AM
Robincanmakeit
Sep 28, 2016 02:12 PM
colsoncj
Ozarks
20
Apr 2, 2008 07:20 PM
MossyRocks
Jun 2, 2006 08:09 PM
