Gear oil fill bolt
Old Apr 18, 2015 | 03:44 PM
hexrain's Avatar
Gear oil fill bolt
1994 22re truck (manual) 2wd
So here is my problem. I doing a clutch for the first time today. Got everything disassembled, with not near enough of the right tools, but I digress. So i set my tranny aside (a little off level) and where the driveshaft connects in the back, a milky oil mixture starts leaking out. I looked it up, and apparently since my 270k truck still had stock clutch and pressure plate (and i'm assuming gear oil too) there must have been 270k worth of condensation in there.
So I went to open it up and apparently the previous owner had stripped out the fill bolt. I tried cranking it, pb blaster, putting the wrench on and hammering a breaker bar to loosen, dremmeled it down to a 16mm from 17mm, and no luck just stripping it more. the thing is super stuck. tommorow is sunday and i have to have this truck up and running by monday morning at 5:30 for work.
So now to the questions. should i just flush it with some gear oil and then put 2.5 quarts in it (i read this is the capacity) through the shift hole? is there another way to judge the level besides having the fill plug open? is it bad if i put too much oil in there? is it reasonable to suspect that my rear diff. is in the same state assuming it hasn't been changed? what is the best way of freeing up this bolt?
Thanks Yota warriors!
Old Apr 18, 2015 | 04:13 PM
lethe's Avatar
I don't remember what the capacity is off the top of my head but i would fill it through the shifter hole like you mentioned. Thats how i do it.
Old Apr 18, 2015 | 04:19 PM
hexrain's Avatar
thanks for the response. any idea of what could happen if i overfill? judging by what happened i imagine the extra would just leak out around the driveshaft.
Old Apr 18, 2015 | 04:49 PM
hexrain's Avatar
also, from reading about it, i guess no oil should be escaping around the output shaft... so do i need to replace that then also, or might i have just unseated it when pulling the driveshaft?
Old Apr 18, 2015 | 05:11 PM
Shagool22's Avatar
Weld a clean not stripped bolt head to the fill plug and get it out. Then go to www.marlincrawler.com and order new fill and drain plugs. Very cheap. I highly recommend ordering a shifter seat as well!! Takes a lot of slop and play out of shifer
Old Apr 18, 2015 | 05:16 PM
lethe's Avatar
Changing the seal on the rear output of the transfercase is easy. A impact wrench will make removing the staked nut a lot easier.
Old Apr 18, 2015 | 05:30 PM
hexrain's Avatar
awesome suggestion shagool, hadn't thought of that! but in the meantime since i dont have access to a welder for a good while i still need to get a feel for capacity and whether overfill will harm anything. i dont have an impact unfortunately.
Old Apr 18, 2015 | 08:59 PM
RSR's Avatar
RSR
You can always have a new bolt (head) welded to your old... Probably the easiest way to to do it. Then remove and replace...
Old Apr 18, 2015 | 09:18 PM
Shagool22's Avatar
I believe mine took 3-3.5 quarts. Als lost as your in the 3quart range that outta do until you can take care of the stuck fill plug
Old Apr 18, 2015 | 09:21 PM
Shagool22's Avatar
I don't think a little overfill will hurt anything, if you completely over fill it might be hard on the seals I'd imagine that being the only harm you could do.
Old Apr 18, 2015 | 09:33 PM
Shagool22's Avatar
Sorry I just re read your post and realized your 2wd.. If you read capacity is 2.5 qts then put that much in and call it good until you get a chance to look into removing the full bolt
Old Apr 19, 2015 | 05:40 AM
Mr. No SPAM's Avatar
How does the height of the fill plug relate to the height of the rear seal area? If the rear opening is about the same height on the tranny as the fill plug is you could leave the drive shaft out and fill until the oil comes out where the seal goes, or over the over the seal lip itself.
It also makes sense to just fill it with whatever quantity you determine is correct and call it good.
Old Apr 19, 2015 | 05:51 PM
hexrain's Avatar
i put a little more than 2.5 in but i also changed the seal. im think its probably good but im going to end up changing the fluid again soon, as i think there is probably more milky oil still remaining.
i test drove after the new clutch and it is awesome! i think my clutch must have been going out the whole 4 months i have had the thing. it took out all the hesitation i was having and it has way more acceleration. just awesome all around! that was kind of an intimidating job to do by myself for the first time but im stoked that it went great. who needs a tranny jack anyway... good thing the tranny only weighs like 100 pounds.
Old Apr 19, 2015 | 06:46 PM
Shagool22's Avatar
Glad you got her rippin again. Good job, and yes a brand new clutch is one of the greatest feelings haha
Old Apr 19, 2015 | 07:42 PM
grumpin's Avatar
Great! Nice when it works out well!
Old Apr 27, 2015 | 03:06 AM
hexrain's Avatar
I ow have a weird rattle, clang, possible grinding going on after the change. I have a post in 2wd forum. I need help!
Old Apr 28, 2015 | 09:40 AM
Shagool22's Avatar
Could be a number of things.. Did you torque flywheel and clutch plate to spec? Something could have come loose. You're gonna have to pull her apart and take a look!!
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
87blyota
Jul 10, 2015 04:31 AM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
