Gas coming out of exhaust??
Old Aug 5, 2010 | 06:15 PM
Lunnzz's Avatar
So I just recently helped a buddy rebuild his 3.0 and we tried to fire it up today and we got it running. The two problems that we have are it does not want to idle and there is a large amount of gas coming out of the exhaust any and all help would be great.
Thanks
Old Aug 5, 2010 | 07:29 PM
thook's Avatar
Is there any fuel in the intake and/or manifold as well? If it's just the exhaust, sounds like an injector or injectors are stuck open.
Old Aug 5, 2010 | 10:10 PM
Lunnzz's Avatar
There is very little in the intake manifold. He got the injectors from a local place called Dr. Injector they actually looked new. The intake manifold was cold on the back side when we did have it running which made me think the cold start injector was messed up but with it unplugged it did the same thing.
Old Aug 6, 2010 | 04:53 AM
thook's Avatar
Where'd you look in the intake manifold to find fuel?
The only way fuel could get in the manifold is through the EVAP canister vacuum lines, the fuel pressure regulator vacuum lines, or the cold start injector. Unless you somehow have some other lines royally misplaced. That would have to be fuel lines, though. In which case, I really don't think the vehicle would run....
Anyway, pull the cold start injector from the plenum with the electrical and fuel still connected. Place a cork or something similar in the plenum (that won't get drawn in) and turn the motor over. The cold start injector should stop injecting once the vehicle is running. Also, check if there's fuel in the vac lines from the EVAP and regulator.
Old Aug 6, 2010 | 06:50 AM
Lunnzz's Avatar
Will do when i get a chance I suspected it might be the cold start injector.
Old Aug 6, 2010 | 10:08 PM
Lunnzz's Avatar
Well walked out to the truck today after it sat over night and most of the day to find gas dripping on the ground. So I popped the hood and there was gas coming straight out of the throttle body so now what?
Old Aug 6, 2010 | 11:15 PM
vital22re's Avatar
totally a bro
cold start injector leaks probly. Unplug it and remove it from the intake manifold while keeping the fuel line attached turn the key on so it primes the system and see if its leaking.
Old Aug 7, 2010 | 09:51 PM
Lunnzz's Avatar
Anybody got a close up pic of where the fuel return goes searched didn't find what I wanted.
Old Aug 7, 2010 | 09:58 PM
thook's Avatar
Did you check the regulator and EVAP can vacuum lines?
Old Aug 7, 2010 | 10:04 PM
thook's Avatar
Read this thread, please.......
https://www.yotatech.com/forums/f116...s-help-217147/
Old Aug 8, 2010 | 08:18 AM
Lunnzz's Avatar
All I need is a pic of where the fuel return line goes. Will check on the cold start injector.
Old Aug 9, 2010 | 09:17 AM
thook's Avatar
Well, I was hoping the thread might give you something more to go on. I guess not.
I don't have any pics of the return line. But, it should come off the fuel rail somewhere. I'll have to look at my wife's 3vze and get back later.
Old Aug 9, 2010 | 04:46 PM
Lunnzz's Avatar
I think I got it figured out I just want to change the oil first since it has gas in it and it is not my truck. Good thing we didn't really mess with it too much when we realized we had an issue.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
ryerye13
Jul 14, 2015 08:27 AM
smiley52
Jul 11, 2015 05:16 AM
Jnkml
Jul 6, 2015 01:20 PM
