fuel smell in exhaust, smoke, and fouling plugs after head gasket repair and headers
Old Nov 30, 2013 | 07:39 PM
  #41
Flame Thrower's Avatar
FormerVendor
Originally Posted by VT94Runner
So i picked up a cheap syring and had some hose laying around, i made a little pressure tester for the flamethrowers. filled with injector cleaner and tested with my trusty 9v.
Three of them performed perfectly, two even streams squirting out on each each with the 9v battery.
Two of them performed correctly but in between touches dripped gas
One of them shot gas out when it felt like it, otherwise just dripped when it was touched.
ok. did you try this with a square wave at 12v?
Old Nov 30, 2013 | 07:40 PM
  #42
VT94Runner's Avatar
They are the orange ones, I messaged the ebay seller (is that you?) about a refund, but before I do that I want to make sure that my factory ones work. Now I just need to find some pintle caps and quick.
Old Nov 30, 2013 | 07:41 PM
  #43
VT94Runner's Avatar
I don't have a 12v battery unfortunately to test them with that.
Old Nov 30, 2013 | 07:51 PM
  #44
VT94Runner's Avatar
well I guess I have my car battery? Is that recommended?
Old Nov 30, 2013 | 08:10 PM
  #45
FormerVendor
yes. use your car battery. injectors will not work properly on 9v.
Old Nov 30, 2013 | 09:07 PM
  #46
VT94Runner's Avatar
Did you by chance read the whole thread? Do you think that the issue's I'm having are in line with leaky injectors? I will test out with my car battery tomorrow morning.
Old Dec 9, 2013 | 12:37 PM
  #47
VT94Runner's Avatar
Just wanted to follow up. The eBay seller for flamethrowers sent me a replacement for the faulty injector and things are working well. I spent way too much money on this rebuild but I know its done right. Ended up picking up a new Flowmaster CAT. So New heads and gaskets, flamethrower injectors, LCE headers, Flowmaster CAT, and flowmaster muffler. Should be smooth sailing from here.
Just need to fix the one coolant line I cracked on the last plenum remove and I will be back to disturbing the neighbors with my "loud old truck"
Thanks for all who helped.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
steve miller
Oct 10, 2015 01:40 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
karbin
Jul 5, 2015 11:37 PM
