fuel pump replacement
Old Oct 30, 2013 | 01:13 PM
tjdwyer's Avatar
Im going to replace my fuel pump tomorow and i was wondering if there is anything i should be careful about and how hard is it to do it?
And do you have to drop the gas tank?
1992 toyota v6 3.0
Old Oct 30, 2013 | 05:48 PM
wyoming9's Avatar
Red face
Since you don`t mention if it is a Pick up or a 4Runner
Then you don`t mention what part of the world you live in.
the worse part is when you break the fittings on the fuel pump bracket or the bracket .
Also removing the bracket can be interesting in itself.
Old Oct 30, 2013 | 05:57 PM
MattWeb's Avatar
fuel pump is in tank. fuel filter is more accessible located under passenger side on my 94 pickup
Old Oct 30, 2013 | 06:07 PM
tjdwyer's Avatar
oh oops my bad and its a pickup and in north america but its been done like 5 or 6 years ago but it was a cheap one
Old Oct 31, 2013 | 05:57 AM
arlindsay1992's Avatar
On the Pickups the tank needs to be dropped, or the bed removed. Make sure you have a good set of flare wrenches. Rusty tank mount bolts might hold you up a bit. They are in a convenient place to drill out if need be. Just drill it out, replace with any bolt and nut.
Old Oct 31, 2013 | 07:28 AM
Dan Carey's Avatar
Watch the rear wiring if you lift the bed. Soak your fastening hardware with WD or similar before you start
Old Nov 1, 2013 | 07:26 PM
dkvde1's Avatar
my 87 4 runner may have a bad fuel pump. how can i isolate the problem? 4 runner runs great, but intermittently sputters when going thru gears.problem is getting worse.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
