Fuel Pump... Electrical Problem
Old Sep 1, 2008 | 11:14 AM
HAWAIIANSTYLE's Avatar
changed my fuel pump, filter, regulator, brand new circuit opening relay and still having problems turning over. after installing the relay and the fuel pump i had a partner turn the key to the on position to check if i could hear the pump turning on. it didnt work. i jumped the pump from the battery with a set of jumper cables to test if i hooked it up right and it worked, the pump turned on. i then re-connected the plug and tried it again and still no sound of the pump turning on. no power coming to the pump. im thinking either my wires gone bad or power cut off before the COR. PLEASE HELP
Old Sep 1, 2008 | 12:01 PM
abecedarian's Avatar
check all the fuses first.
also, check the COR plug is getting power with the key either with just the key turned on, or when trying to crank.
Old Sep 1, 2008 | 12:08 PM
aviator's Avatar
Might be a problem with the fuel pump bracket. I just had my pump done and had to get a bracket also because the connector at the bottom [submerged in gas] was in poor condition... and a spark there would be bad.
jbv808
Aug 6, 2021 04:47 PM
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
Yota.Jay
Jul 23, 2015 08:08 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
