Fuel pump assembly thread size
Trying to plumb the fuel to my ls1, using 3/8's nylon fuel line. The piece coming out of rhte fuel tank has a flared fitting that goes inside a female fitting on a rubber line for about 6 inches then to another fitting. What size fitting is this? I need something to go from this to a 3/8 nylon barb. So frustrating!
Why would you be using "3/8" fuel line on a motor vehicle? When was the last time SAE-dimensioned parts were used on any motor vehicle (including US-built)? 1970?
I'm not sure what an ls1 is, but I'm sure it doesn't use 3/8" fuel line. Why don't you just get regular 10mm steel line (and borrow the bender for free) and save yourself a lot of work.
I'm asking for the size of the fitting on the fuel pump assembly. Not for your apparent lack of knowledge.
Get out of my thread.
Reminds me of Harrison Ford's "Get off my plane" in Air Force One.
It's apparently an easy to find size. If you live in Japan. This week I'm going to Midwest Hose, if they can't figure it out, then I'll probably be having to reflare it.
Or... Pirate came up with 6AN Male to M14x1.5 Female INVERTED FLARE
http://www.pirate4x4.com/forum/toyot...k-fitting.html
Piranha Racewerks Fuel Line Feed Adapter
Fuel Line Fitting Adapter 6AN - M14x1.5 Female INVERTED FLARE
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Kluch8651
Jul 9, 2015 10:39 AM
