Fuel Pressure Leak
Old Oct 5, 2010 | 03:47 AM
DanStew's Avatar
Fuel Pressure Leak
I got this truck and it always was a bit hard to start after it sat for a few days. I lived with it. I had my injectors rebuilt because of a differnt issue, and at the same time i was hoping it would have fixed the issue. It didnt. I jumped the fuel pump so it will automatically turn one with the key switch turned on, and it didnt help. I have no fuel leaks at all.
This morning I decided to turn the key on and let the fuel pump pressurize the system, and after 10 seconds i cranekd it up and it started right up. So I know I definately have a leak down in the fuel system. My actual question is what is next in the system I should check out? The fuel pump seems to work. I can hear it pumping when i have teh key switch turned to let it pump. Since the issue happened before and after i changed the injectors. And when i installed the injectors i changed the filter. Would the check valve go bad but not the pump? I know my charcoal canister does have a vacuum line to the throttle body, but i am not sure that will have an effect on this issue.
Thanks for the help.
Old Oct 5, 2010 | 05:02 AM
TNRabbit's Avatar
if this a 3vze or 22re? Do you smell gas? If it's a 3vze, check the fuel pulsation damper (rear of passenger side fuel rail), and fuel pressure regulator (front of driver side fuel rail).
Old Oct 5, 2010 | 05:19 AM
DanStew's Avatar
it is teh 22re. No fuel smell. No leaks at the regulator or fuel rail.
Old Oct 5, 2010 | 07:33 AM
myyota's Avatar
It is possible for the check valve in the pump to go bad and not hold presure. If the pump has a lot of miles on it the check valve has probably worn out.
Old Oct 9, 2010 | 06:40 PM
DanStew's Avatar
I know the truck has 204,000 on it. I believe the pump is original. i may have to pull the body cover in the 4runner to look at the top of it.
jbv808
Aug 6, 2021 04:47 PM
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
nick b
Jul 11, 2015 04:38 AM
