Fuel mileage qestions...
I just got back from a 400 mile roundtrip drive, and figured my mileage to be about 21 mpg. It was all highway miles, and including going crossing the Cascade mountin pass each way, so alot of uphill driving.
Its a '94 extra cab 22re, with less than 1,000 miles on the rebuild, and it's stock except for 31'' tires.
At first, I was anticipating better mileage from the almost eclusive highway driving, but then I remembered that much of the trip was spent tackling an incline going over the pass... What kind of mileage should I be able to expect, otherwise?
Also, are there any simple bolt-ons that will improve power without affecting mileage when I keep my foot out of it? I know its partly the nature of the truck, but having to drop down to 4th gear on some of those hills to keep it above 60 miles per hour would be nice to avoid.
Thanks for the input!
I think 21 is pretty good for a 22re and hills with 31's and stock gears. I get close to that with my 88.
Only thing I can really think of to help mileage is advancing the timing as much as possible without pinging and driving with a light foot. Re-gearing to a ratio more appropriate for the 31's might help some too.
I often drop down to 3rd to hold 65 in my 88, and have done so many times without issue with the engine at 3500+ rpm's.
The trick with mileage is the least amount of throttle applied with the appropriate gear in order to maintain speed.
I made nearly the entire pass without dropping out of 5th gear more than 3 times, only in the steeper areas.
I found it kinda odd that 5th gear, which I thougt of as an overdrive, is only roughly 400 rpm lower than 4th gear at 65 miles per hour... does that sound right? Either way it was always enough power that I could accelerate up those hills, and maintain 65.
just to clarify... it is a completely rebuilt motor, bored over, balanced, and a 260 cam...
So what MAF from a supra should I be looking for? What's the idea behind that exactly? and is it just a direct swap?
Thanks!
Thanks!
heheh, dude, you said stock! bored & cammed is not stock
is your mileage calculation corrected for running 31's with 4:10 gears?
I don't get particularly great mileage with combo city/highway - around 17-18mpg, but with mostly flat highway at ~60-70mph, I get around 23mpg.
bored how much? the larger displacement in theory will hit your fuel economy.
and yeah, like Gnarls said - whose cam?
I just filled up my '94 Xtra cab this morning after a typical week of city driving: 306 miles / 14.6 gallons = 21 MPG. When I last used a whole tank on the highway with a 70 MPH speed limit, I got about 26 or 27 MPG. Those numbers have been pretty typical for me since I bought it new 140,000 miles ago (it's still completely stock). So, your numbers sound low to me.
I do know that my mileage is correct, or as correct as it can be acccording to mapquest. It was just a straight shot of 194 miles on the freeway, parked it, then returned the next morning.
I'll have to look up those cam specs.
Sep 4, 2015 09:27 AM
Tacoma1313
Aug 17, 2015 05:44 PM
anniesball
Jul 30, 2015 12:14 PM
