fuel line crush gasket p/n?
Old Feb 15, 2016 | 10:00 AM
128keaton's Avatar
Hello folks! I've been having a whale of a time with this engine. I got it all back together to have the fuel rail leak. I need the crush seals for all of the banjo bolts, and I think I need the one for the larger banjo at the end. Does anyone have the p/n? Thanks!
Attached Thumbnails fuel line crush gasket p/n?-0900c15280092787.jpg
Old Feb 15, 2016 | 10:28 AM
scope103's Avatar
There are three sizes: http://www.toyotapartsoverstock.com/...rimLevel=18186 This dealer (in Florida) is where I order my crush washers; price is right, they're quick, and spread over the 18 washers you need, the shipping doesn't cost much.
18? Yes, take my advice: order (at least) 2 extra of each size. There is a reasonable chance you'll carefully torque a joint together and realize you need to take it apart. You can't reuse these washers (not even once), so having the spares will save you a world of grief.
And for what it's worth, I've never found these washers anywhere but at a dealer. You can't cheat on the size; both the inside and outside diameters are important.
Old Feb 15, 2016 | 12:41 PM
128keaton's Avatar
Thanks scope! Just got back from the dealership, and I have the p/n for the seals I needed. Here are the part numbers (TOYOTA numbers):
* The Rail->Rail seals are: 90430-12026. I ordered 10 of these.
* The Rail->Plenum seals are: 90430-08012. I ordered 8 of these.
* The Large Banjo->God-knows-where seals are: 90430-18028. I ordered 4 of these.
You need one for each side of the banjo bolt, so two PER bolt. I ordered extras, as recommendation by Scope
Old Feb 15, 2016 | 01:53 PM
scope103's Avatar
Originally Posted by 128keaton
... I ordered extras, ...
Price? My brick-and-mortar dealer (which I really like) is a lot higher than the mail-order dealer I cited. Good for 2 washers (because of the shipping cost), but once I pass two I'm willing to wait for the USPS.
Old Feb 15, 2016 | 01:59 PM
128keaton's Avatar
$38. I was guaranteed they'd be here tomorrow or my money back. The shipping was free. Its a bit steep, but this is my only car and I have classes and work this week, everyday.
Old Feb 15, 2016 | 03:25 PM
scope103's Avatar
That's less than $2 each. You are definitely ahead of the game!
Old Feb 15, 2016 | 04:46 PM
MudHippy's Avatar
In case anybody has any other questions:
http://www.toyotapart.com/3VZ-E_FUEL...T-EG015-91.pdf
Old Feb 15, 2016 | 05:54 PM
scope103's Avatar
Well that resolves that: they're tin plated. They just look like aluminum.
I see that the '93 manual has the updated torques: http://web.archive.org/web/201208130...68cylinder.pdf
Old Feb 16, 2016 | 05:27 AM
128keaton's Avatar
Perfect! This is a good thread. Hopefully it will help someone else
Old Feb 16, 2016 | 06:12 AM
MudHippy's Avatar
They're the same as the TSB. See page EG2-260. With my personal edit.
Delivery pipe x Pulsation damper 22 ft-lbf
Delivery pipe x Fuel pressure regulator 22 ft-lbf
Delivery pipe x Cold start injector 11 ft-lbf <-- This means both ends of the CSI tube.
Delivery pipe x No. 3 fuelpipe 25 ft-lbf
Delivery pipe x No. 2 fuelpipe 25 ft-lbf
And pages EG2-84 & EG2-86 from the link you provided.
(a) Install the No.2 fuel pipe with four new gaskets and two union bolts.
Torque: 34 N–m (350 kgf–cm, 25 ft–lbf)
(b) Install the No.3 fuel pipe with four new gaskets and two union bolts.
_________
(k) Connect the cold start injector tube with two new gasket and the union bolt.
Torque: 15 N–m (150 kgf–cm, 11 ft–lbf)
Nineonerunner
May 5, 2022 10:20 AM
Lewis
Feb 21, 2016 01:45 AM
medicmoose
Feb 14, 2016 09:05 AM
4by4yoter
Feb 13, 2016 08:32 PM
vikecowboy
Feb 9, 2016 07:31 AM
