Fuel injector problems
Old Mar 14, 2019 | 12:55 PM
Jens4runner's Avatar
I'm having problems with my 91 4 runner is it possible to over tighten fuel injectors
Old Mar 14, 2019 | 03:25 PM
snippits's Avatar
What is the problem? Which engine?
Old Mar 15, 2019 | 05:06 AM
Injector problems
Its the 3vze 3.0 my husband rebuilt the injectors be we're wondering if you can over tighten them and if so what will happen if you do
Old Mar 15, 2019 | 08:16 AM
ev13wt's Avatar
5 Year Member
Aren't they just stuck there between the intake and the fuel rail? As in they don't screw down?
https://www.yotatech.com/forums/f116...s-3vze-293282/
Old Mar 15, 2019 | 09:00 AM
scope103's Avatar
Hard to imagine you could "over tighten" injectors.
Here's the manual; look at page 227 http://web.archive.org/web/201311071...90injector.pdf The fuel rail is tightened to only 9 ft-lbs (the rail has rubber isolators, so you COULD over tighten the rail. I'm not sure that would directly affect the injectors.) Note that you should be able to rotate the assembled injectors (the gasoline "lubricant" allows the o-ring to rotate). The manual advises that if you can't rotate them, you probably messed up the o-ring.
And if you did that, I would expect leaking.
Good luck!
Jens4runner
Mar 14, 2019 12:51 PM
outdoorjunky
Sep 21, 2018 06:14 PM
Luvmeye22re
Sep 13, 2012 10:01 AM
RedneckBatmobile
16
May 23, 2012 06:39 AM
camaross
Apr 1, 2009 05:08 PM
