Fuel Filter Location :QUICK!:
Old May 8, 2007 | 09:51 AM
celica860's Avatar
Been doing a tune up on the 89 4runner and I can't find the fuel filter to save my life. (maybe its due to the caked dirt?) But could someone please tell me what its next to or something? Everyones told me its on the frame rail but I cannot find it to save my life, any help??
Old May 8, 2007 | 10:01 AM
Godzilla's Avatar
engine type? 6 or a 4?
Old May 8, 2007 | 10:08 AM
Godzilla's Avatar
If its a 3.0 this may help;
https://www.yotatech.com/forums/f128/fuel-filter-replacement-3-0-v6-engine-76356/
now it may have a metal guard on it which may make it tougher to see like the picture in the link..easiest way is to start closer to the rear and follow the fuel line up.
Old May 8, 2007 | 10:25 AM
Teva02's Avatar
on the 22RE I think it sits on the passenger side of the engine block doesn't it?
Old May 8, 2007 | 10:45 AM
4Hummer's Avatar
22RE Under the intake plenum above the starter. PITA to get to
Old May 8, 2007 | 10:49 AM
Tdubbs05's Avatar
passenger side right above the transmission crossmember. it's kind of hard to get to. here:https://www.yotatech.com/forums/showthread.php?t=76356
Old May 8, 2007 | 12:09 PM
celica860's Avatar
How the heck do you get to these things, I've been trying for an hour with no luck...this makes me wanna commit suicide ... j/k
Old May 8, 2007 | 12:12 PM
all_terrain17's Avatar
Well since you don't want to reveal your engine, we can guess it's the 4cyl from what you've written. There's a black hatch on the passenger side wheel well that will help out a lot getting to it.
Old May 8, 2007 | 01:08 PM
celica860's Avatar
well i have the fuel lines removed, oh...yea sorry about that one guys..its a 4cyl. But ne ways, I've got the lines removed now all thats holding me is getting the top bolt off!!
Old May 8, 2007 | 02:08 PM
celica860's Avatar
Ok...NEVERENDING!! Where's the Pcv Valve!!!??? ERGH!!?
Old May 8, 2007 | 03:08 PM
ovrrdrive's Avatar
Any chance of you shooting a video of yourself working on the truck and posting it up?
I bet it would be very entertaining...
PCV valve is on top of the valve cover between a rubber hose and a rubber grommet on the valve cover.
Old May 8, 2007 | 03:11 PM
ovrrdrive's Avatar
Here:
Old May 8, 2007 | 06:01 PM
gametom's Avatar
the fuel filter is'nt that bad to replace on the 22re
Old May 9, 2007 | 05:46 AM
rdlsz24's Avatar
^^Especially when you have a body lift with no wheel well splash guards and you can lay on the front tire on your stomach and change it
I have a quick question regarding fuel filters as well. My truck was a factory v6, but now has a 22RE (previous owner swapped it in). So I have 2 fuel filters: the one on the frame near the passenger door and the one on the block of the 22RE. Would it be possible to eliminate the one on the frame with some rubber fuel line hose? What could it hurt? I figure it's easier than changing it.
Rob
Old May 9, 2007 | 07:00 AM
celica860's Avatar
[QUOTE=rdlsz24;50522634]^^Especially when you have a body lift with no wheel well splash guards and you can lay on the front tire on your stomach and change it
Good for you!! haha. Well I do have splash guards and all that jazz but after some busted and bruised up knuckles and hands; everything is fixed and working wonderfully. Next is the exhaust leak ... I feel like I'm a druggy every time I ride in that thing.
Old May 9, 2007 | 07:09 AM
thook's Avatar
Rob
Yes it would. I had to use some rubber line to make a splice when the fuel line sprung a leak above my fuel tank. I only used it, though, until I had the time to drop the tank.
Metal line would be better. A flaring tool, some fittings, and a short piece of tube would be easy enough and cheap enough to install as a permanent repair.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
