Fuel
I take my best source as Bill Wattenberg, one of the smartest guys in the country (really) who flatly states that all modern engines will run fine on regular, and anything else used in a stock engine is a big-time waste of money (and a scam). He states that this is not just an accident, but a legal requirement.
I run 87 unless I am towing. It pings like crazy towing with 87. I think my plugs might need to be gapped, I didnt pay attention when I installed them....duh.... and the plug wires arent toyota, maybe that will help if I replace them.
I try to run premium as often as possible, if I dont the 22r-e runs crappy (in comparison) and pings like crazy. I hear that here in AZ we have crappy-ass gas though. Could be a myth?
87 on all machines... And I do run the 3VZE advanced a bit. Nothing pings and should not according to the best sources I have.
gas with higher ethanol content supposed give lower MPG but is supposed to be cheaper and save you money in the end. i use 87 octane E10 rated from 76 in my Runner with a 3vze. the gas station i go to costs the same as the others that have no additives so that's why i go to 76. it's done me good so far.
22re's, and 3vze's should run on 87 if theyre all working properly and in spec. There are some performance cars that run on higher grades, as well as anything with a supercharger/turbocharger. Anyonw who tells you that their car/truck gets better mileage with premium is crazy unless its knocking, and the knock sensor is retarding the timing. The higher the octane, the lower the btu's. thats just the way it is.
Pure Gasoline has about 125k btu's/gallon while 10% ethanol gas has about 121k btu's/gallon so you will get better gas mileage with the non ethanol stuff, but a lot of the northeast 10% ethanol is all thats available now.
Correct. Its a point some people do not get because it is counter-intuitive. That is, the more expensive gasoline has less energy per unit volume than the cheaper gas. Lots of people just love to feel-good about putting the more expensive gasoline as they feel they are taking the best care of their vehicle.
Most of you know that what the higher priced gasoline does is slow down the burn-rate, avoiding pre-detonation, which is a waste of energy.
But I repeat. All modern engines are required to run on regular gas regardless of what some manufacturer's say in the owners manual. This is accomplished by various sensors that determine optimum air/fuel, timing etc. That includes Hondas VTEC's with high compression ratio (>11), for example.
yes all engines can run on 87, however some high compression engines are designed to run on higher grades, and when they run on lower grades they tend to knock, and the knock sensor will change the way the computer is running the engine (fuel, timing, etc.). A lot of cars that are designed for higher grades are actually cheaper to run on the higher grades becase of the performance loss.
Also it should be noted that even though there are less btu's in higher octane gas, the higher octane gas can actually create more power in a high compression engine because it runs more efficiently
