frustated
Old Sep 20, 2008 | 07:19 AM
jeffvntn41's Avatar
frustated
please help my son has a 94 yota truck 4 cyl r22 it will start and barely idle wont run u push gas pedal at all it dies i checked fuel pressure from fuel pump good 40 lbs bought new fuel pump not it? bought fuel pressure regulater not it? bought fuel filter not it?i am not a mechanic just tryin to help son im tired of buyin parts give me any ideas please simple ones first as i said i am not a mechanic at all jeff
Old Sep 20, 2008 | 07:32 AM
black diamond's Avatar
make sure all the air intake is on good and tight, no leaks. any trouble codes, engine light on?
Old Sep 20, 2008 | 07:45 AM
racingcameron66's Avatar
that truck has the 22re, it has 2 fuses, one for idle and one for more gas flow, so go look at your fuses
Old Sep 20, 2008 | 08:11 AM
jeffvntn41's Avatar
thank u very much
thanks i wished i talked to you 3 hundred dollars ago u r a life saver i am an idiot my son says thanks too jeff
Old Sep 20, 2008 | 08:12 AM
jeffvntn41's Avatar
i had to many shade tree mechanics givin me advise
Old Sep 20, 2008 | 08:45 AM
scuba's Avatar
did you ever find the problem ?
Old Sep 20, 2008 | 08:48 AM
your very welcome, that will be 500 dolla haha j/k
Old Sep 20, 2008 | 11:14 AM
scuba's Avatar
so was it those fuses ?? I'd like to know what the actual problem was
Old Sep 20, 2008 | 01:45 PM
jeffvntn41's Avatar
fuse
it was the fuse scuba thanks for replyin it started and ran right after i changed it but now after u kill it it dont want to start for awail it acts like its flooded its spits and sputters then when it cranks it runs good but kill it and same pproblem again help????????
Old Sep 20, 2008 | 10:03 PM
now that beats the hell out of me! bad ground???
va slim
Oct 26, 2009 04:26 AM
