Front main crank seal
Old Nov 2, 2009 | 04:02 PM
4runnerguy's Avatar
i just i have put over 5 front main seals in this truck within the year.
what is causing the seal to go?
its a 3.slow 5speed
Old Nov 2, 2009 | 04:05 PM
TOYOTA 1's Avatar
groove in the balancer?
Old Nov 2, 2009 | 04:33 PM
slacker's Avatar
yep .. time for a "speedy sleeve"
Old Nov 2, 2009 | 04:36 PM
RetchedOne's Avatar
x2
Old Nov 2, 2009 | 04:48 PM
Teuf's Avatar
LOL Slacker , for the life of me i could not remember the name of the sleeve, i was like quick sleeve , happy sleeve, mmmm dang.
Old Nov 2, 2009 | 05:21 PM
Tragic Drive's Avatar
So I gotta ask.. Can you do it in under 30mins?
Old Nov 2, 2009 | 05:26 PM
Pigman's Avatar
Only if he's the worlds fastest "Flat Rater" LOL
Old Nov 2, 2009 | 05:29 PM
4runnerguy's Avatar
ya i need to check but there never was any rips or anythin on the seals.
Old Nov 2, 2009 | 05:30 PM
4runnerguy's Avatar
45 min to an hour what takes longer is the antifreeze
Old Nov 2, 2009 | 05:34 PM
jsn_stockard's Avatar
I have had a sleeve come loose before. It caused me to be towed in 100 miles from the trail
Old Nov 2, 2009 | 05:44 PM
Teuf's Avatar
? Are some aftermarket oil seals, or OEM, offset such as to contact a diff part of the shaft surface. Mine has dripped here n there forever, no biggy .
Old Nov 2, 2009 | 05:52 PM
4runnerguy's Avatar
all oem they are cheaper then the aftermarket. any one has the pic of the sleave u guys are talkin about
Old Nov 3, 2009 | 06:38 AM
4runnerguy's Avatar
bummp
Old Nov 3, 2009 | 12:10 PM
TOYOTA 1's Avatar
http://www.class8truckparts.com/CR-S...source=froogle
not the right one, but you get the idea.
Old Nov 3, 2009 | 02:07 PM
4runnerguy's Avatar
thanks toyota 1
Old Nov 3, 2009 | 08:57 PM
Teuf's Avatar
Thanks also 1, i can use info too.
Old Nov 4, 2009 | 05:04 PM
bugs1961's Avatar
You've probably figured this out by now but the 3.0 front crank seal actually rides on the crankshaft itself and not the balancer. You have to pull the timing belt to get to the seal so it's a little bigger job than 45 minutes, for me at least.
sandyota
Feb 4, 2021 11:16 AM
redneck17
Jul 17, 2015 07:44 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
