front 7.5 ifs question
Old Sep 27, 2008 | 03:17 PM
krepas's Avatar
hi
the front 7.5 axle on 4 runner 1995 it's different than 7.5 axle from 4runner 2000 are totallly different...but ring & pinion on those axles are different or no?
thanks
Old Sep 27, 2008 | 05:28 PM
crolison's Avatar
totally different
older = low pinion
newer = high pinion
the only thing compatible are lockers
Old Sep 27, 2008 | 08:00 PM
krepas's Avatar
Originally Posted by crolison
totally different
older = low pinion
newer = high pinion
Thanks...
Old Sep 27, 2008 | 08:15 PM
iamsuperbleeder's Avatar
this may be a dumb question, but why is it that even though everything is completely different, the lockers are still interchangable between them???
Old Sep 27, 2008 | 08:33 PM
Matt16's Avatar
The carrier size is the same, just the gear teeth are cut differently.
Old Sep 27, 2008 | 08:34 PM
ah ok, I was just all "wtf?" there for a sec, lol
Old Sep 27, 2008 | 10:41 PM
Matt16's Avatar
Basically, as I understand it, in our trucks the front diffs are rotating "backwards" when traveling forwards. The gear teeth are stronger when the drive side is taking the load. On our trucks the coast side of the teeth take the load when traveling forward.
On newer trucks, they flipped the diff upside down, so the drive side of the teeth was being loaded when going forward.
From Pirate4x4:
Ring Gear Tooth Nomenclature
A – Top. The top of the gear tooth, a.k.a. Face, Top Land
B – Root. The bottom of the gear tooth, a.k.a. Flank
C – Heel. The outside-diameter-end of the gear tooth
D – Toe. The inside-diameter-end of the gear tooth
E – Coast. The concave side of the gear tooth*
F – Drive. The convex side of the gear tooth*
* Don’t be mislead by the terms “coast” and “drive”, as the ring-gear can be driven by the pinion on either side of the teeth. Which side of the teeth will depend on if the gear-set is standard or reverse spiral and whether the vehicle is going forward or in reverse.
Old Sep 27, 2008 | 10:43 PM
pic no work... but I understand what you're talking about
Old Sep 27, 2008 | 11:39 PM
krepas's Avatar
From Pirate4x4:
Great info...
I understand the difference on our axle and newers...
Thanks from Mexicali Mexico....
Old Sep 27, 2008 | 11:47 PM
Matt16's Avatar
You're welcome from Vancouver, Canada.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
oldirtydirt
Feb 23, 2020 09:30 AM
deepmarsh
Aug 6, 2015 03:44 AM
rushw
Jul 18, 2015 01:46 PM
