Free Power From The 3.0!!
Old Mar 12, 2008 | 10:17 PM
  #41
stormin94's Avatar
Originally Posted by infiltrator
Yeah, cutting a hole in the black bottom bumper would sound like a good idea. I think I will keep mine the way it is with my ISR for now. I need to fix my retarded headlight it points down. I finally found out what the problem is. There is a small metal mount inside that broke. If I squeeze my fingers in, I can glue it back together. Im going to try that.
Both my headlight mounts are broke on both sides. I know how that feels, but mine are plastic.
Old Mar 12, 2008 | 10:23 PM
  #42
infiltrator's Avatar
At least yours are even . One of mine is straight, the other is down lol.
Old Mar 12, 2008 | 10:32 PM
  #43
stormin94's Avatar
Not quite. One is off to the right, a lot, and the other is down. It's like it has a lazy eye.
Old Mar 15, 2008 | 05:00 PM
  #44
idanity's Avatar
why not a hood scoop ?
i know some e30 (bmw) tuners delete the high beam for the same reason, but they have 4 headlights.
if you have to have your intake in that spot, you could also hallow out a larger diameter around the light and it would still function from the sides of the light (or install a tiny high beam, as on some newer highend models- ellipsoid type)
either way. keep an open mind.
Old Mar 18, 2008 | 04:47 PM
  #45
DJK-West's Avatar
Wasup guys,
I'm in the City of San Fernando, nice to see some local Yota fans in the forum! I removed that plastic air funnel behind the driverside headlight just to see what it'll do and my truck is idling alot smoother! Can't say that my rig actually accelerates more as it might be just a placebo effect. But I like the way the engine is running at the moment, smooth. I wouldn't want to loose one of my headlights as I have HID conversions in there.
Old Mar 23, 2008 | 08:39 AM
  #46
87AzRunner's Avatar
JCM4x89PU
could you take some pix of this setup, like a few close-ups, i wanna try this
and cant really come with any good ideas looking at my intake. much appreciated
Old Mar 23, 2008 | 11:41 AM
  #47
JCM4x89pu's Avatar
Originally Posted by 87AzRunner
JCM4x89PU
well, i hope it would work for you.. i dont know how the airbox on the 22re is set up.. but i will try to get some pics posted.
Old Mar 23, 2008 | 11:47 AM
  #48
JCM4x89pu's Avatar
Originally Posted by DJK-West
Wasup guys,
..i removed that funnel before i took my headlight out.. then i decided to put it back in afterwards. the purpose of the funnel is to isolate the cold outside air from the hot air in the engine bay. when i ran my truck without the plastic air funnel, i was only seeing a 0.1 - 0.3 increase in mpg.. whereas i am seeing a 2.5 - 4 (usually closer to 3) increase in mpg. by removing the funnel you are letting the engine breathe better, so it does help a little, but it causes your engine to suck in hot air from the engine bay.. so the effects are negligible.
Old Mar 23, 2008 | 11:57 AM
  #49
JCM4x89pu's Avatar
lets see if this works...
<a href="http://s294.photobucket.com/albums/mm120/jcm4x89pu/?action=view&current=0312081448a.jpg" target="_blank"><img src="http://i294.photobucket.com/albums/mm120/jcm4x89pu/0312081448a.jpg" border="0" alt="blackeye"></a>
Old Mar 23, 2008 | 11:58 AM
  #50
JCM4x89pu's Avatar
Old Mar 23, 2008 | 11:59 AM
  #51
JCM4x89pu's Avatar
cool it worked!.. enjoy!
  #52
Matt16's Avatar
That thing looks evil to me. I wouldn't want to be tailgated by you. Now go tailgate some Jeeps and scare them off the road.
Old Mar 23, 2008 | 06:15 PM
  #53
87AzRunner's Avatar
thats what i needed, thanks. yeah the 22re is different, i dont have that funnel, but my dad is trading in the 93 runner for a new toyota pickup in june and said i can have that corner funnel then im gonna fab it to fit mine, should be almost a drop in. ill just have to cut a hole in the air box and seal up the old one. thanks for the pix.
Old Mar 23, 2008 | 09:55 PM
  #54
stormin94's Avatar
You should call your truck "One eyed Jack" from now on.
Old Apr 13, 2008 | 09:33 PM
  #55
87AzRunner's Avatar
Black eye!
Got a blackeye too now! i haven't noticed any gains(mpg), but i dont have the funnel piece for the corner yet...
ill have one in june though when my dad trades in his runner.
it seems to have a harder time starting up, but once i get
onto grand where its 65, it feels noticably better, maybe its a placebo
effect though...
any updates on yours?
Old Apr 13, 2008 | 11:44 PM
  #56
Jay351's Avatar
Next time I get some free time, Im going to try this. I need to replace my headlights soon anyways!
tobylab
Jan 18, 2016 07:06 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
tobylab
Jul 12, 2015 12:53 PM
Coreyr384
Jul 10, 2015 11:13 AM
