Found a great tranny cooler
Old Jul 7, 2006 | 10:06 PM
WATRD's Avatar
Originally Posted by ctcost
Well still seems to be working great.
How many degrees was the temperature change between before and after?
Old Jul 8, 2006 | 04:44 AM
ZUK's Avatar
ZUK
ct---I've never quite seen a cooler that BIG.....but the only way to really know if it's cooling EXTRA GOOD is with a temp gauge. If you don't have one then this is the bad boy you should have
http://dynamicracingproducts.com/Aut...roducts_id=472
Old Jul 8, 2006 | 09:07 AM
ctcost's Avatar
Well I don't have a "before" measurement, Anyone have any idea as to the "standard" operating temp for the automatic in a V-6?
Old Jul 8, 2006 | 09:10 AM
WATRD's Avatar
So how are you measuring that it's "working great"?
Old Jul 8, 2006 | 12:40 PM
  #25
ZUK's Avatar
ZUK
I will after I install my AUTOMETER COBALT Trans Temp Tranny Temp 6157. Then when I have a baseline, I will install the Hayden tranny cooler and compare.
Did you bypass the built-in cooler that is in the engine radiator or are you running it in series?
Old Jul 11, 2006 | 07:02 AM
  #26
ctcost's Avatar
I can just tell by feel it's working fine. It's definitely dissapating enough heat when towing light loads. Also, the comment of "working great" was directed at earlier posts asking for on and off performance updates and the worry about it being a "new shiny rock detector". lol
Thanks Zuk. If you can get me those temps it will help with numerical analysis a bit. Had to bypass the radiator cooler as it lost a tube and started leaking.
BeMiceElf
Oct 10, 2015 09:40 PM
Iceman4193
Jul 15, 2015 04:48 PM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
madxman21
Jul 9, 2015 10:26 AM
