Flowmaster part # for a 91 2wd pickup?
Old 09-14-2006, 10:18 AM
Elton's Avatar
i would only go with 2.25" pipes but if you like to you can go with 2-1/2'' after the muffler for sound... if you where to stand next to my truck at idle where the exhaust exits my truck it sounded great had a real deep sound to it
Old 09-14-2006, 11:58 AM
ovrrdrive's Avatar
Originally Posted by 91RN81
hey guys should i go 2.25 or 2.5 tailpipe, the guy at the muffler shop says hes got only 2.5 flows. will this be ok? i want that deep sound.
The 2.5" muffler opening will slip right over a 2.25" pipe. That way they can weld right to it without using a neckdown adapter.
For the exit, definitely use a larger size pipe. I ran 2.5" out the back to the tip, but I honestly wish I had run 3" instead. The back pressure you're going to get will be from the pipe to the muffler, the rest is just tailpipe and for sound. A larger diameter tailpipe will give a deeper note.
Old 09-14-2006, 12:14 PM
dcg9381's Avatar
He can use adapters or make it work with 2.25.
You'll probably lose power with a 2.5in exhaust.. That is if you were to do it all the way back. If you've still got a stock cat, stock manifold, etc, this is a bit of a silly discussion anyway (IMHO).
Want it to sound deeper? Add a header.. It'll sound deeper and perform better. Going stock manfold -> stock cat -> stock pipe -> 2.5" flowmaster -> exit is
Old 09-14-2006, 01:55 PM
91RN81's Avatar
Sorry but not everyone has the money to front for headers and full exhaust. I'm starting from the back first then i'll get to the rest of the exhaust as money becomes avail.
Old 09-14-2006, 02:38 PM
  #25
dcg9381's Avatar
I absolutely understand that.. My point is that rather than spend $100 on a muffler that isn't going to make any difference over a $20 muffer, you might want to save that $80 towards a header... :-)
Old 09-14-2006, 05:52 PM
  #26
Elton's Avatar
heres the magnaflow muffler http://www.hottexhaust.com/detail.asp?PRODUCT_ID=11215 $65 shipped and the cat http://www.hottexhaust.com/detail.asp?PRODUCT_ID=94105 $64 shipped
Old 09-14-2006, 08:53 PM
  #27
91RN81's Avatar
Good point, didn't think of it that way. I guess it's too late now but gonna work more hours to save up some money. i usually get the best so im thinking of going with the LCE header. Any noticeable power/torque differences or is it just in our heads, lol? thanks guys for all the advise.
Old 09-14-2006, 09:19 PM
  #28
Elton's Avatar
seat of the pants i noticed it pulled harder from 1400-4200 rpms also it shaved a few hundred rpms off of 60mph as in well get better mpg i think it was by far the best mod i did to my 22re
bigblue82
10
07-06-2015 08:27 AM
Wid
07-01-2015 11:54 AM
DanStew
06-29-2015 10:46 AM
paxanders
06-21-2015 06:29 AM
trancenotic
08-11-2002 08:25 PM
Quick Reply: Flowmaster part # for a 91 2wd pickup?
