First tech - vacuum leak?
Old 02-09-2006, 12:16 AM
rcm3's Avatar
So, like I said in the other posts - oil change and spark plugs to come. Done and done. I went with dino-oil with plans to do the autoRX thing and switch to syn but it looks like I am losing some oil below so that will have to wait until I investigate. I certainly don't want to make things any worse.
I used AutoLite Platinum plugs.. opinions welcome.
The reason I replaced the plugs is because things felt a big sluggish. I know how everyone talks about how slow the 3.0 is but mine is less perky than it should be I think. Things are definitely a bit smoother with the new plugs/fresh oil, but I am suspecting that maybe there is a vacuum leak causing some hesitation upon acceleration. I hadn't messed around under the hood much until last night. I don't think I have ever seen such a mess of vacuum hoses.
The QUESTION I guess is where to start looking for the air leak and other potential power losses. Thanks for reading!
Old 02-09-2006, 03:01 PM
rcm3's Avatar
Oh. And my next project will be to replace the blower motor resistor. It only works on fan speeds 3 and 4 (of 4).
Old 02-09-2006, 03:19 PM
PirateFins's Avatar
Easiest way is to get a can of sensor safe carb/intake cleaner and spray the vacum hoses and fittings one at a time and listen to the motor. If you spray a hose/fitting and the motor RPM's increase without touching anything else then you have found a leak. Works every time.
I have to replace my blower motor resistor also. I have speeds 1,2 & 4 but no 3.
raptor510
02-17-2017 07:11 AM
_Nicco_
08-28-2015 07:26 PM
raptor510
08-19-2015 02:15 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
nick b
07-11-2015 04:38 AM
Quick Reply: First tech - vacuum leak?
