Finally dug into my rear axle project today...
Old Mar 5, 2011 | 09:13 PM
TNRabbit's Avatar
It was sounding ROUGH so I parked it about a month ago. I had let the rear end run almost dry of gear oil from a loose fill hole fitting over the past few months. Diff has a whine & some play, the driver side bearing was GONE & gear oil was EVERYWHERE:
Old Mar 5, 2011 | 09:15 PM
Elton's Avatar
wow good thing u stop driving it could of locked up on you
Old Mar 5, 2011 | 09:19 PM
TNRabbit's Avatar
Yeah, well; it was making so much noise I figured it would have in the next 20 miles~
I wish I'd made a video of how much play was in the bearing...I could move the wheel a half inch!
Old Mar 6, 2011 | 04:46 AM
rattlewagon's Avatar
Woah. That bearing was toast! So whats the plan for this axle? Re build and keep running it?
Old Mar 6, 2011 | 05:47 AM
waskillywabbit's Avatar
That should be fun.
:wabbit2:
Old Mar 6, 2011 | 06:11 AM
TNRabbit's Avatar
Yep. Eventually looking at a locking or limited slip diff.
Originally Posted by waskillywabbit
That should be fun.
:wabbit2:
No doubt!
I have a 12 ton press so no problem getting it apart~:wabbit:
Old Mar 6, 2011 | 10:19 AM
Having the right tools at hand is always a plus. A locker would be cool!
Old Mar 7, 2011 | 12:37 PM
TNRabbit's Avatar
Pulled the other axle in the rain yesterday...not as bad. I think I am missing an oil seal for each axle....there's an o-ring, inner and outer seal, and bearing, right? crap.
Old Mar 7, 2011 | 01:17 PM
b4wheeler's Avatar
Sucks working in the rain, and it rained like a mother yesterday......
Old Mar 7, 2011 | 01:42 PM
yotaman90's Avatar
Old Mar 7, 2011 | 04:02 PM
TNRabbit's Avatar
Originally Posted by yotaman90
Sorry; moved them in Photobucket. I've re-entered them all in the first post #1...
Old Mar 7, 2011 | 04:03 PM
TNRabbit's Avatar
Here's three of the four parts (doh!) you'll need for this project. The fourth is the inner oil seal, which I'll be picking up tomorrow:
Old Mar 7, 2011 | 04:28 PM
skoti89's Avatar
Good choice on the OE bearing. Don't put the chinese crap in there. Toyota or an Altrom 936 bearing is great.
Old Mar 7, 2011 | 05:05 PM
iamsuperbleeder's Avatar
you don't have to worry about them locking up on you as much as you do them letting loose and letting the axle shaft slide out of the axle tube while you're driving
those things were definitely shot though! if you've got a press, it's a pretty easy job
Old Mar 7, 2011 | 08:43 PM
barrel roll's Avatar
What? Non c-clip axles don't do that...
Old Mar 8, 2011 | 02:09 AM
TNRabbit's Avatar
These have the c-clip...
Old Mar 8, 2011 | 06:34 AM
Well that's weird. Mine doesn't. I wouldn't be able to pull the axle without opening the diff. and removing the c-clips if I had c-clips. I can't even find the c-clip in the diagram in the service manual for 86.
Old Mar 8, 2011 | 06:55 AM
TNRabbit's Avatar
The c clips are right behind the bearing...they are the retainer for the bearing assembly. You can see it in this pic:
I think we're talking about different c-clips...
Old Mar 8, 2011 | 07:06 AM
blake.nemitz's Avatar
good luck ge3tting the old bearings off. i stalled a 50 ton press and caused runout in one shaft, so after finding a replacement i cut the cage off the ball bearings so i could seperate the inner race from the rest, still stuck on axle, put it in a wood jaw vise and cut the inner race with a cut off wheel almost to the axle, then smacked it with a fat wide punch causing it to crack where i had cut a groove. then it slid right off. i hope this helps i have done several with this method and seems to be as fast if not faster than rigging everything up in a press. however if you can press it out effortlessly thats cool too
Old Mar 9, 2011 | 06:41 AM
TNRabbit's Avatar
If you stalled a 50 tons press, it sounds like you didn't remove the C clip....???
