Fast turn signal
Old Jan 12, 2016 | 08:37 AM
adamhairfield's Avatar
Fast turn signal
I recently put a flatbed on my '94 Toyota Pickup and purchased a normal light box convertor to hookup the lights on the flatbed. It does not have LEDs just standard lights. Now whenever I hit the brakes the turn signals flash extra fast. Is there an easy/good way to fix this issue? I have been looking around for awhile now and can't find any good answers.
Old Jan 12, 2016 | 12:53 PM
kcaudill's Avatar
Check your wiring, you messed something up
Old Jan 12, 2016 | 12:56 PM
metalhed's Avatar
burned out bulb or a grounding issue
Old Jan 12, 2016 | 04:56 PM
Everything is wired correctly and no burnt bulbs. I've been reading and seen a couple different places that if you put resistors on the turn signals it fixes the issue.
Old Jan 13, 2016 | 11:11 AM
Any thoughts on the resistors?
Old Jan 13, 2016 | 12:37 PM
scope103's Avatar
Originally Posted by adamhairfield
... purchased a normal light box convertor to hookup the lights ...
What is a "normal" light box converter? Do the instructions tell you how to install it? Why do you need it?
Old Jan 13, 2016 | 12:56 PM
wyoming9's Avatar
Red face
I gotta love it you build a flat bed and go cheap on lights !!
Run all the lights out of one light fixture so you need to get a trailer converter box
That is why the Op needs a box.
I always Run separate lights even on the trailers I build.
I would venture a problem already with the Converter box unless you messed up your wiring
Old Jan 13, 2016 | 02:15 PM
I didn't do the build. I bought it from someone else. I already have a trailer converter box.
Old Jan 13, 2016 | 03:26 PM
PukaWai's Avatar
Usually means a burned out bulb. There are electronic flashers that will always flash at the same rate, normally used for LED conversions since the old tech flashers depend on a specific current through the circuit, but the electronic work on all bulbs.
Old Jan 14, 2016 | 12:01 PM
Below is the link to the trailer convertor that I currently have on the truck.
http://www.oreillyauto.com/site/c/de...0158&ppt=C0386
Old Jan 14, 2016 | 12:02 PM
Also, here is a shot of the lights on the bed.
Old Jan 14, 2016 | 12:04 PM
dropzone's Avatar
Fossilized
Either the converter is bad or it is wired wrong.
Check your grounds again. You would be surprised how one that loops fine will screw things up
Old Jan 14, 2016 | 12:06 PM
I'll check the grounds. My father helped me wire it up and he is an electrical engineer, he mentioned adding resistors to the turn signals. Have you heard of that?
dropzone's Avatar
Fossilized
Seeing that you have 2 red lights on each side (just like the stock tail lights) by pass the converter and use the two inside lights as your brake lights and the outside lights as your turn signals.
Yes I have heard of using resisters but only when using LED's.
Edit- are those lights used? That could contribute to your issues
Old Jan 14, 2016 | 12:09 PM
That's a good idea. What about the three smaller brake lights in the center?
Old Jan 14, 2016 | 12:36 PM
wyoming9's Avatar
Red face
Those 3 lights should just be marker lights
I am sure if you want you could wire them as brake lights depending on your state laws
I agree with Dropzone use the lights as he described .
Old Jan 14, 2016 | 12:44 PM
Great, I'll try it out and get back with y'all. Thanks!
Old Jan 14, 2016 | 11:53 PM
abecedarian's Avatar
I am sure if you want you could wire them as brake lights depending on your state laws....
State laws regarding lighting are trumped by FMVSS 108.
Old Jan 16, 2016 | 12:47 AM
wyoming9's Avatar
Red face
So then just what does FMVSS -108 say ??
How does one know when State Law is enforced over Federal ??
Brings back Memories of the good old 73,280 days
xtremewlr
Nov 6, 2015 11:26 AM
Curoso
Nov 3, 2015 04:42 PM
deerleasetruck
Nov 2, 2015 03:13 PM
☆OMI☆
Oct 31, 2015 10:54 PM
Elinoregt350
Oct 18, 2015 12:23 PM
