Fan Bracket Won"t Fit on 3.0
Old Dec 30, 2008 | 02:57 PM
tyndalltoy's Avatar
Hey Gang. I recently replaced the water pump,timing belt and both idler pulleys on my 95 4runner 3.0 . When I went to put on the fan bracket, it was hitting the #1 idler pulley. I took off the new idler and put on the old one...same result. When I take the idler pulley off completely, then the fan bracket goes on smooth. When I put on the new timing belt on ,everything lined up and the pulleys lined up after 2 rotations. I already tried looking through alot of the threads, no luck , just frustration. If anyone has any ideas or pictures on how it should fit on or look .........PLEASE help. thanks
Old Dec 30, 2008 | 05:07 PM
lham's Avatar
fan bracket
Is it a new fan bracket or the old one & is the idler pulley adjusted correctly?
Old Dec 30, 2008 | 06:02 PM
Cyberman's Avatar
And that is a tensioner, not an idler that the bracket is hitting.
Old Dec 30, 2008 | 06:20 PM
tyndalltoy's Avatar
It's the old fan bracket and I thought that you can only adjust the tension once the fan bracket is installed??
Old Dec 30, 2008 | 06:49 PM
abecedarian's Avatar
got some pics?
Old Dec 31, 2008 | 04:19 AM
lham's Avatar
fan bracket
You need to adjust the tensioner, then install the fan bracket.
Old Dec 31, 2008 | 04:56 AM
Cyberman's Avatar
on the 95, the tensioner mounts to the fan bracket. Seems like something isn't installed right.
Pics would help...
Old Dec 31, 2008 | 06:30 AM
lham's Avatar
fan bracket
I was thinkin about my 90 model
Old Dec 31, 2008 | 08:29 AM
zlathim's Avatar
Seems like I ran into this same problem a few months back. IIRC, I had the tensioner on completely wrong. Sorry I can't be much help, but the fog that is my memory isn't telling me much.
Old Dec 31, 2008 | 03:54 PM
tyndalltoy's Avatar
I tried to post a couple of pics but it said my file was to big. I'll try to make them smaller and post them again.
Attached Thumbnails Fan Bracket Won"t Fit on 3.0-img_6751-small-.jpg   Fan Bracket Won"t Fit on 3.0-img_6748-small-.jpg
Old Dec 31, 2008 | 03:56 PM
tyndalltoy's Avatar
Good ...it worked. Hopefully these will show enough. Happy New Year !!!!!!!!!
Old Dec 31, 2008 | 04:47 PM
DeathCougar's Avatar
You need to install the fan bracket first, THEN bolt the hydraulic tensioner into the fan bracket. It will then pull the timing belt tight.
Old Dec 31, 2008 | 05:02 PM
tyndalltoy's Avatar
I can't get the fan bracket over the idler pulley. I took the tensioner off before I tried putting the fan bracket back on.
Old Dec 31, 2008 | 05:33 PM
Well i guess I am not seeing it then. you have everything installed correctly. Sometimes you need to pull up a little bit on that tensioner pulley, since there is enough slack to let it hang down and contact the bracket.
Old Dec 31, 2008 | 08:08 PM
tyndalltoy's Avatar
I'll give it a shot. We'll see if it will be a good start to a new year!!
Old Jan 1, 2009 | 03:36 PM
Cyberman's Avatar
Ya, that idler should move to the right a little, tighten the belt, and the bracket should fit over. The idler is moving, right?
Old Jan 1, 2009 | 04:02 PM
tyndalltoy's Avatar
I finally got it set up. There is a bolt hole just behind and off center from where the idler bolt should have been. Well...... as the famous saying goes "Learn from your mistakes". Thanks for all your help. CHEERS!!!!
Old Jan 2, 2009 | 06:09 AM
zlathim's Avatar
Yep, that's what happened to me too. It's all coming back to me now. Wrong hole, but it looks pretty normal.
Amer
3.4 Swaps
19
Jun 5, 2017 10:43 AM
BeMiceElf
Oct 10, 2015 09:40 PM
coryc85
Sep 9, 2015 06:24 AM
jackiebrownia
Jul 20, 2015 09:02 AM
1996Taco
Jul 20, 2015 12:02 AM
