fan on a 3.0
fan on a 3.0
is the engine fan soposed to sound like a jet going down the highway. I drive a semi and is as noisy as a semi fan. its a 1990 3.0 and the cluch is nice and stiff . as I would expect it to be.
It should sound like a jet engine right after you start the engine and then quiet down 20-30 seconds latter. If it sounds like a jet engine after this then the clutch is worn out and needs replacing. You can get a new oem aisin unit from rock auto. The clutch should be failrly loose feeling after a 30 min drive. Is there oil all over the clutch?
The clutch contains a type of oil, if it leaks out it can cause problems.
Lce makes a new fan for your truck, what they do is take the fan clutch off and replace it with a new fan and a spacer between the fan and engine, that should take care of the problem or you can just replace the fan clutch and be on your way, your choice
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
