The Famous Starter-NO Click
Old Oct 11, 2011 | 07:46 PM
repda916's Avatar
Trying to help a friend fix her car, Its a 95 Toyota 4runner Sr5 AUTO v6...She said she parked it, came back out tried to start it and nothing.
Starter was replaced with a new one-No click
Battery was replaced-No click
Jumped car- Same thing, No click
Replaced the wire from + to the fuse box -No click
When the key is in ACC power and everything works, Headlights shine bright with no dim.
When key is turned to try and start, the click dims out.
there is a "starter" relay in fuse box and also another relay along side of that near fire wall that clicks when one tries to start it. Tapped both of them while friend tried to start thinking they were stuck, Nothing.
Tapped starter thinking it was stuck, Nothing.
Any help? car is stranded
Old Oct 11, 2011 | 08:04 PM
Land Pirates Off Roa's Avatar
Usually it is the starter contacts... But with a new starter, have no idea unless we were there... Sorry, we suck at electrical unless we have a tester in hand. =-(
Old Oct 13, 2011 | 03:42 AM
skypilot's Avatar
Ignition switch. Power goes through the switch vice a relay. Both my trucks have it, so I ran a jumper switch with a fuze.
Old Oct 13, 2011 | 05:44 AM
repda916's Avatar
you have more info? Diagram ?
Old Oct 13, 2011 | 07:00 AM
skypilot's Avatar
Just run a 12ga wire from the battery with a fuze (2.5A) to a push button switch inside where its good for you and then from the switch to the solenoid terminal on the starter.
Or you look at the prints in the FSM and you will see power flows through the ignition switch and the contacts have failed. You could hot wire the starter relay also (stick). If its an A/T check your neutral start switch
Old Oct 13, 2011 | 10:13 AM
yotarover's Avatar
make sure it's in P or N, i went though the trouble to change out my stater,wiring, of course i changed my oil and filter while i was down there. just to find out i spent all that time when it was just in drive..
Davebarbier
Nov 3, 2015 03:28 PM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
Papadeath
Sep 14, 2015 10:26 PM
