Famous "high idle/surge" culprits!
#601
point blank:
the cylinders have been bored oversized... so appropriately sized pistons need to be supplied... and rings to match the bore and pistons are needed as well.
boring may add some cleareance since the boring is a 'rough' machining process and 'honing' is a 'fine' process. it is techinally possible for the honing process to add another .010 (ten thousands) to the bore diameter
there is some leeway between the piston size and the ring size
I know I need bigger pistons (.030) but now what?
#605
Should be picking up my block today. I bought an intake (the piece that I bent) for $10 with injectors! lol.
Now I need to clean everything up...and put it back together. I'll take some pics when I get my block. Thanks!
#608
#612
See there is my problem. They are still in the block...so how do I remove them? Am I supposed to use a sealant to put them back in or something like that?
#617
if you've bought new bearings all around, then yes, plastigauge them just to make sure the clearances are correct and if they're not, take the bearings back and get the proper sized ones.
did you figure out the rings? there is a tool called a 'ring spreader' made specifically for getting the rings on the pistons.
#618
Yeah...I'm pretty sure my dad has that tool. I might just have to buy one though. Should I plastigage EVERY one...or just one and call the rest good? lol. That would kinda be skipping a step though. It should be WAY easier now since its on a stand. Thanks!
