factory EGR block off????
Old Apr 14, 2009 | 04:13 PM
Junkers88's Avatar
Doing some looking on the 89 (22re) and I noticed a newer looking piece of hose. So I pulled it and found out it's a plug stuck into the end of a vac line. It's the vac hose that goes from the top of the EGR to one of the holes on the plug that comes out of the intake, about 6 inches long. As crazy as this sounds could this thing be the reason why I'm still getting an EGR CEL code?? Or is it a factory block off?
Hell I might just pull it and see what happens.
edit I found a picture. Ignore the blue stuff.
The line I'm talking about (red arrow) is the one that comes out of the EGR near the edge of the deck (disk/whatever you call it). Although on mine it comes up and goes into the little black 3 pronged thing (yellow line) on the intake.
Old Apr 14, 2009 | 04:18 PM
yoterr's Avatar
i gots one of them doohickeis too, just not on the egr stuff its on one of the lines on the side of the carb, it seems like a plug to me too, just dunno
Old Apr 14, 2009 | 04:54 PM
Junkers88's Avatar
Ok I went back out and looked and where that hose goes in the picture is a little metal nipple with a hole in it. With the engine running it poofs out little bursts of air. So I hooked it back up, pulled the + cable to clear the codes and we'll see if the CEL comes back on this week while I drive to work. I'd love to eliminate that last engine code.
I wonder if it'll help me get better milage? Heck I only got 21.25mpg on the last tank.
Old Apr 14, 2009 | 05:04 PM
jason191918's Avatar
Do you have cali truck? If not, it shouldn't make a difference. Only the cali trucks have the egr sensor.
Old Apr 14, 2009 | 05:07 PM
Junkers88's Avatar
I have the EGR Gas Temp Sensor and from what I've seen on some of the diagrams only the Cali trucks came wiith that little gem. It might have come from out west.
Old Apr 14, 2009 | 05:08 PM
abecedarian's Avatar
As far as I can tell, it's a check valve. It lets the engine suck one way (to turn the egr valve on) but doesn't let any vacuum from the egr valve suck from the engine.
Old Apr 14, 2009 | 05:34 PM
Junkers88's Avatar
You mean the one in the blue circle? That's not my drawing, I had to find that picture.
edit. I did find a great diagram over at Pirate and the little valve thing in the intake is indeed only supposed to have two hoses connected to it and one nipple plugged. The line from the top of the EGR does indeed go to a little metal nipple that runs down along the valve cover to the front of the motor and connects to the bi-metal vacuum switching valve. It is now hooked up correctly as far as I can tell. Tomorrow when I have more light I'll run all the vac lines to be sure nothing else is incorrect.
Old Apr 14, 2009 | 06:12 PM
iamsuperbleeder's Avatar
that picture looks familiar
Old Apr 14, 2009 | 06:40 PM
Junkers88's Avatar
Yup. I used one of yours out of an old thread I found while searching. I know how to use the search function.
Old Apr 14, 2009 | 07:02 PM
Originally Posted by junkers88
yup. I used one of yours out of an old thread i found while searching. i know how to use the search function.
holy crap, someone does!!!
Old Apr 14, 2009 | 08:36 PM
BigBluePile's Avatar
there's a search whaaaa??
Old Apr 14, 2009 | 09:55 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
What is this "search" you are speaking of?
Old Apr 16, 2009 | 08:15 AM
well it's day after tomorrow so...?
Old Apr 16, 2009 | 08:16 AM
click on the word "search" in the menu bar then type in "search" (without the quotes) and it'll tell you.
Old Apr 16, 2009 | 09:37 AM
Lol
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Iceman4193
Aug 28, 2015 08:43 PM
accuracy
Aug 4, 2015 08:05 PM
e_richard
Jul 30, 2015 06:50 PM
montanatruck
Jul 25, 2015 03:45 AM
