Extra oil port
Old Mar 15, 2015 | 10:58 AM
swampfox's Avatar
Extra oil port
I recently installed a sr5 cluster in my 89 2wd , and after 12 years of watching the idiot light going off, I found that I miss having it. My work day starts before daylight and having the light was handy when doing the mourning warm up. I have noticed that there is a plug in the center of the motor mount in line with the oil sender .My question is has anyone tried hooking a oil gauge to this port. The oil pressure sending unit will thread into the hole . This might be a cheaper way to add a mechanical gauge or idiot light . When time allows I plan to try checking to see if it is an oil port and if has pressure at it. So far I have been been experimenting on a motor that has been setting for years and any oil that was there is long gone.
Old Mar 15, 2015 | 11:35 AM
Terrys87's Avatar
I have wondered about that port as it is just plugged with a bolt. Curious as to what you find.
Old Mar 15, 2015 | 11:40 AM
Odin's Avatar
Try it. I'd love to have a real mechanical gauge
Old Mar 15, 2015 | 12:03 PM
swampfox's Avatar
Curiosity got the best of me , I pulled the plug out of my dd and oil came out , but the hose on my pieced togather oil pressure gauge, wouldn't bend enough to do a oil pressure test.
Old Mar 15, 2015 | 02:45 PM
xylicon's Avatar
I use both ports, I put the small idiot light sending unit in the port that rests inside the engine mount, it fits just fine in there.
Old Mar 15, 2015 | 02:52 PM
swampfox's Avatar
Thanks for the reply ,I will rig myself up a idiot light when time allows.
Old Mar 15, 2015 | 07:11 PM
Punchy's Avatar
Cant use both the gauge and the oil light at the same time, Well on my SR5 gauges you cant, The oil light bulb shorts the power away from the gauge.
Old Mar 15, 2015 | 07:15 PM
jp63's Avatar
Old Mar 15, 2015 | 07:47 PM
xylicon's Avatar
I should've noted that I do not have an SR5 cluster.
Old Mar 15, 2015 | 11:34 PM
wyoming9's Avatar
Red face
You can put a tee in a mechanical gauge line any place it is easy to reach.
Then you can have your light being you miss it so.
I have Mechanical gauges in most of mine
Old Mar 16, 2015 | 01:28 AM
Odin's Avatar
Aaand there we go.
When the time comes I'll be ACE Hardware
, GW Hardware, Lowes, Home Depot bound.
Old Mar 18, 2015 | 04:53 AM
hotrodchriz's Avatar
They are both oil plugs and travel through the same oil passage and both the same thread as the oil pressure switch so all you need to do is buy a mechanical universal oil pressure gauge from you favorite auto parts store and run straight into either of the two ports. You could even installed a 90 degree elbow so the clear oil pressure line won't kink on you if our prefer.
Old Mar 18, 2015 | 05:18 PM
swampfox's Avatar
On my truck I plan to rig up a stand alone light and use the check engine socket on the cluster. The main thing needed is a bulb socket with pig tails, that will plug into that place on the cluster. Since my truck doesn't have a ecm it is not used anway.
Eggslinger
Jun 8, 2019 03:32 PM
RatOmeter
Oct 22, 2015 03:17 PM
Poppie51
Jul 23, 2015 05:03 PM
the1998sr5
Jul 16, 2015 06:20 AM
HRDC0R19
Jul 5, 2015 06:43 PM
