Exhaust smokes... help!
Old Jun 23, 2005 | 10:19 PM
dragon564's Avatar
Okay I checked the squish post about some one brakes and I provide this quote here
Quote:
Originally Posted by mt_goat
It works fine for me but try this one: http://personal.utulsa.edu/~nathan-buchanan/93fsm/ or this one http://www.4x4wire.com/forums/showf...=5&o=14&fpart=1
That link will take you to an online 3vz FSM the compression test section states:
@250RPM
normal:171 PSI
Min: 142 PSI
Diff 14 PSI
Check the link for all the details......acrobat reader required......
Old Jun 23, 2005 | 10:22 PM
Yamaha+Toyota=Fun's Avatar
try smelling your coolant, if it smells like exhaust its probally the headgasket. Have you cooling system preasure tested. Etc. Blown Headgaskets are no fun, but can be fixed. Make sure it is blown before you start tearing it apart though.
Old Jun 24, 2005 | 06:10 AM
CynicX's Avatar
Originally Posted by 4RUNR
That’s a first. I'd think that everything that matters during a compression test would expand at the same rate, thus making cold/hot irrelevant.
here are the directions from my snap on guage in pdf. I think its describe on the 3rd or 4th pages...
Click
I would still think this is a head gasket problem if in fact that is coolant. As mentioned try smelling it and maybe run it for a minute while its doing that then pull the plugs and see if thats oil or antifreeze.....
You can have the radiator pressure tested as mentioned. I think sometimes though it wont show a head gasket leak if it requires more pressure then a little pressure tester can provide, like the engine its itself. Its worth a shot though....
Old Jun 24, 2005 | 08:57 AM
DudeBud's Avatar
you could pull the needle valve out of the compression gauge and use the ait compresser and blow in the compression gauge line. look for air bubbles in the radiator
Old Jun 26, 2005 | 10:52 AM
  #25
iGGz's Avatar
Howdy... well we borrowed the air compressor from the neighbors and did this and it did bubble... so the head gasket is screwed lol... but anyways we are tearin it all apart right now... and he said since we have it this far apart we should get a new cam...
What cam do you think would be the best? What else should we change in it since its this far apart? Timing chain?
Thanks Ian
Old Jul 7, 2005 | 04:55 PM
  #26
iGGz's Avatar
Well we took the head out and took it to a machine shop and they said it was cracked... hmmm...
But I guess I am really kind of in luck... my moms boyfriend owns a "junk yard" basically and he has a ton of older toyota trucks and 4runners... and most are torn apart and one has a good head thats out of it already... so that put me in a good mood hah...
Thanks for all you help guys...
Ian
Steven.m.paulk
Jun 7, 2020 10:45 AM
the_supernerd
Oct 1, 2015 09:20 PM
voiddweller
Sep 28, 2015 11:21 PM
Keithstoyota
Sep 27, 2015 07:29 AM
