Exhaust and Cat, lets settle this
Old Nov 16, 2008 | 12:03 AM
SR5's Avatar
SR5
#1 doing exhaust and a high flow cat to N/A engine is not going to produce a hole lot of power, about 5whp
#2 2 1/2" is to big, you need between 2 1/8 (stock) to 2 1/4
#3 Most "Modern" cats about 10 years or newer are in essence high flow as is
so, i want to hear YOUR feed backs on what worked for you, and what you have seen work, Flowmaster, Edelbrock, Magnaflow, Dynomax, etc..
Old Nov 16, 2008 | 12:07 AM
SR5's Avatar
SR5
i was considering running a high flow cat from Magnaflow or NWOF, anyone have price specs on these, i cant seem to find them
Exhaust i was thinking Flowmatser 40, 44, or new 50 series delta muffler, but i dont know which to choose and last,
id like to find some Intermediate pipe, (pre-bent) that i can buy, shops charge to much,
anyone know were to get some 2 1/4
Old Nov 16, 2008 | 12:32 AM
Elton's Avatar
magnaflow high flow cat about 65 ish from ebay
Old Nov 16, 2008 | 07:36 AM
PirateMcgee's Avatar
On my 93 I'm running a 2 1/4" manifold back mandrel bent magnaflow with a magnaflow hiflo cat. Helped out a lot with a the addition an intake. Sounds great and no droning at hwy. Love this set up.
On the 4runner (bought it this way) 2 1/4" manifold back compression bent with no cat and a flowmaster 40 series. Made only slight difference I belive until the addition of an intake which helped quite a bit. Drones and is pretty loud but sounds ok. I prefer my magnaflow setup.
Either way I think an exhaust is completely worth it on the 22re at least. The stock exhaust sucks, and I noticed both performance and mileage gains. Plus it sounds cool! Intake upgrade complements the exhaust nicely.
Old Nov 16, 2008 | 09:20 AM
SR5's Avatar
SR5
^^ i think i agree more with you, but while i was reading/searching it came up more as not doing much, so thats why i stared this
Old Nov 17, 2008 | 10:35 AM
I definately think it is worthwhile however, on a 4wd pushing larger than stock tires it is really hard to realize the benefits of horsepower increase since usually it is in the higher rpms which are impossible to hit with stocks gears, bigger tires etc. Throttle response is noticeable though.
It does help the ole 22re though.
My 93 2wd benefited from it greatly
Old Nov 17, 2008 | 10:45 AM
91FREERUNNER's Avatar
The magnaflow cats are fairly cheap i paid $40 for a 2 1/2" one for my ford i had Check ebay Id go 2 1/" with a magnaflow cat and muffler magnaflow seems to have the best sound on 4 and 6cyl flowmasters belong on v8s
Old Nov 17, 2008 | 11:19 AM
Wardamneagle's Avatar
And at the high price end of the spectrum....I went LC Engineering stainless, ceramic coated header and their 2 1/4" stainless cat-back exhaust. But then again, I never wanted to touch the exhaust again. Can't say if it helped with the power or not as I changed to a DOA Racing 22RE at the same time.
Old Nov 17, 2008 | 01:09 PM
space-junk's Avatar
im running a chevy half-ton cat and 2 1/2 piping back to a magnaflow muffler and a chrome tip...
definately noticed an increase on the butt dyno, but no idea for sure... revs faster... and it passed smog better than stock, so i guess its good for something...
Bowman5115
Sep 29, 2015 08:55 PM
Bowman5115
Sep 19, 2015 03:04 PM
larrys93pickup
Sep 17, 2015 07:05 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
