Engnbldr T chain kit
Old 11-03-2009, 03:51 PM
pruney81's Avatar
This should be a pretty easy question for alot of people on here.
I'm going to do my timing chain soon and I plan on getting the engnbldr kit with driver's side steel rail. So, my question is what comes in the kit? Is it just a new chain and steel rail or tensioner as well?
I ask because $56 seems like a steal and I was wondering if the kit has all I would need or if I need any additional parts, besides a new cover of course.
Old 11-03-2009, 03:55 PM
olharleyman's Avatar
upper and lower gears , chain , tensioner and gasket's
Old 11-03-2009, 04:04 PM
pruney81's Avatar
that's a good deal, did you use his cover as well?
His parts are from RockAuto or am I mistaken?
Old 11-03-2009, 04:14 PM
flyingbrass's Avatar
Here's what is in the timing box from my master rebuild kit.
Old 11-03-2009, 04:21 PM
pruney81's Avatar
so, what part of the driver's side guide is steel? it's hard to tell from this pic. It looks to me like where the two bolt holes are is steel but the guide is plastic?
Old 11-03-2009, 04:33 PM
iamsuperbleeder's Avatar
the mounting holes are bare steel, and the guide portion is steel as well, but there's a sort of rubberized coating on it
it's a good kit; I run one myself
I also have the Rock Auto cover from engnblder as well; good quality as well
Old 11-03-2009, 04:40 PM
Somewhere around half of the thickness of the driver's side guide is rubber/plastic. I thought it would have more and be made of a harder material. I haven't seen any other metal-backed guides up close, so perhaps this is the norm. Personally, I'd feel more comfortable with thicker, denser material on top.
The passenger side guide is all plastic.
Driver's guide:
Old 11-03-2009, 04:44 PM
How many miles and years have you run this timing kit?
Old 11-03-2009, 04:48 PM
lol, a few months now, about 3500 miles maybe
I installed it with during an entire engine rebuild, at which time I also order from engnbldr a complete engine rebuild kit, .30 over piston set, and Street/RV cyl head with their 261 cam
Old 11-03-2009, 04:51 PM
pruney81's Avatar
that's a good question, how does anyone think the engnbldr kit would hold up as opposed to if I just went with stock Toyota parts. I ask this because my friend works for a Toyota dealer and he gets a discount on parts. He will be helping me with the install as well and he is always knocking "cheap after market parts", so he says.
Old 11-03-2009, 05:15 PM
hands down, the aftermarket steel-backed guide is going to outlast even the OEM full plastic guide...
every once in a while, an aftermarket product DOES surpass OEM quality... it doesn't happen often, ESPECIALLY when talking about Toyota parts, but every once in a while...
Old 11-03-2009, 05:18 PM
874runnersr5's Avatar
x3. for my kit
Old 11-03-2009, 05:24 PM
I guess there no need for me to add anything more other even I too am running the Master kit 268 cam .020 over with this timing kit from eb and have 7-750 miles on mine and you not find a better person or people(Ted&Tod) to deal with and they stand behind their word and products no questions asked 99% of the time.
Old 11-03-2009, 05:27 PM
pruney81's Avatar
I'm definitely going to get it, I just wanted to look at some nice pics and get some reassurance I guess. And Yotatech delivered as always!
Old 11-03-2009, 05:29 PM
I'm no expert, but I stayed at a Holiday Inn.
The positions I've seen are:
OEM, not cheap knock-off, plastic guides are best. They are of good quality (which may also vary over time), not made by some unknown manufacturer using melted crayons or whatever. Good for 100K+ miles. When the plastic wears down enough or whatever happens, they break. You hear the noise and say, "I don't remember feeding spoons into my timing cover." No steel shavings are being ground off and dumped into your oil. Aluminum yes, but at least it's softer.
Metal backed guides are best because even the best plastic ones have a tendency to break. A metal backing plate usually prevents breakage.
As for long-term wear, I don't know. I'm half-tempted myself to buy an OEM plastic driver side guide after seeing this one. My old original driver guide was broken and chewed to hell, but would the metal backed one with the thin, soft coating I have now fare any better? Will it be worse?
Take a look at http://benmlee.com/index.html in general. http://benmlee.com/Engine2/Engine2_timing.htm in particular offers one perspective on timing components. Note that Engnbldr now supplies OSK tensioners.
Old 11-03-2009, 05:30 PM
good choice
On a side note, MAKE SURE you read the instructions that come with the kit. There's specific instructions on installing the new tenioner; it is only tightened to a specified torque spec, that is a tad lower than OEM spec. I think this was actually brought up very recently in another thread. But anyhow, yeah just make sure you read the paperwork
Old 11-03-2009, 05:39 PM
make sure to pull your oil pan and get all them chunks of plastic out of it or you could end up with an even worse issue then just a chewed to hell plastic guide.
Old 11-03-2009, 05:41 PM
12 ft. lbs. max on the tensioner bolts, and use an accurate torque wrench, preferably 3/8" or 1/4" drive, not some 1/2" monster that goes up to 150 ft/lbs. or more and probably isn't accurate at such low settings.
Old 11-03-2009, 05:46 PM
Definitely. If guides are broken (or may have been in the past), pull the pan and clean it out. Otherwise, chunks can stick on the oil pickup screen, block your oil flow, and cause big problems.
My oil pan went off to the machine shop for cleaning along with the rest of my engine parts several weeks ago.
pruney81's Avatar
flyingbrass, that is some interesting reading. There are two ways I could go with this:
1. Save some money and get the engnbldr kit.
2. Spend a little more and get the OEM Toyota parts which will most likely last another 100K miles which will be the life of the truck anyways.
I know a lot of people on here have rebuilt their motor's recently and used engnbldr part's but I would like a response from people who have been running engnbldr kit's for years and tons of miles....
Quick Reply: Engnbldr T chain kit
