Engine Swap
Old Mar 10, 2008 | 01:24 AM
bonesmcgraw's Avatar
Engine Swap
I have a 94 4runner with a v6 that I threw a rod in. I was wondering if anybody knows if the motor mounts on the frame are the same for the v6 as they are the 22re? I know the mounts that connect to the motor are different but I'm not sure about the ones attached to the frame.
Any help is appreciated.
Thanks in advance.
Old Mar 10, 2008 | 02:35 AM
rdlsz24's Avatar
The frame mounts are more towards the front of the truck on the 22E:
https://www.yotatech.com/forums/f116...e-swap-132464/
Rob
Old Mar 10, 2008 | 08:47 AM
thank you for the help
Old Mar 10, 2008 | 08:49 AM
Victor's Avatar
The motor mounts, bell housing pattern are different. You could swap in a 3.4 from a newer 4Runner - there are hundreds of posts on that here if you search.
Old Mar 10, 2008 | 10:56 AM
Elvota's Avatar
I think the 3.4 is going to be your best bet.
Good info threads here:
https://www.yotatech.com/forums/f160/
Old Mar 17, 2008 | 09:04 PM
fuzzmaker's Avatar
Does anybody have any info or experience swapping a chevy v8 small block into a 2nd gen 4Runner. I would like to use my existing 5 speed manual trans and hopefully find a custom bell housing, motor mounts etc.
Thanks
Glenn
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
