Engine Swap
I have a 94 4runner with a v6 that I threw a rod in. I was wondering if anybody knows if the motor mounts on the frame are the same for the v6 as they are the 22re? I know the mounts that connect to the motor are different but I'm not sure about the ones attached to the frame.
Any help is appreciated. Thanks in advance. |
The frame mounts are more towards the front of the truck on the 22E:
https://www.yotatech.com/forums/f116...e-swap-132464/ Rob |
thank you for the help
The motor mounts, bell housing pattern are different. You could swap in a 3.4 from a newer 4Runner - there are hundreds of posts on that here if you search.
I think the 3.4 is going to be your best bet.
Good info threads here: https://www.yotatech.com/forums/f160/ |
Does anybody have any info or experience swapping a chevy v8 small block into a 2nd gen 4Runner. I would like to use my existing 5 speed manual trans and hopefully find a custom bell housing, motor mounts etc.
Thanks Glenn |
