Engine running rough
Old 10-15-2013, 02:05 PM
railroader010171's Avatar
I have a 1990 truck with 22re engine. It will idle but a little rough when cold. With WOT the engine revs up and then right back down. It does this the whole time with WOT. Anyone know what I should do? Thanks
Old 10-15-2013, 03:32 PM
Gamefreakgc's Avatar
Can you expand on "With WOT the engine revs up and then right back down."? We don't have enough info in your post to help us help you.
Old 10-15-2013, 05:32 PM
Kiroshu's Avatar
Sounds like a dirty throttle body.
Check intake air hose for damage.
Old 10-15-2013, 05:49 PM
When I open throttle all the way open its revs up then back to idle and continues to do it while the throttle stays completely open. I did take intake hose off and it is covered with dirt and grime. What can I clean it with?
Old 10-16-2013, 05:11 PM
Kiroshu's Avatar
Throttle body cleaner/Carburetor cleaner.
Old 10-17-2013, 03:08 PM
Got cleaner today and sprayed in and cleaned it out but still ran the same way. So I pulled plug off of the TPS and cleaned it. To my surprise it fixed my problem. Thanks for your help. Now I have to figure out where the oil leak is. Slinging oil all over the front of engine.
Old 10-17-2013, 07:39 PM
Kiroshu's Avatar
Glad you found your problem.
Oil leak at the front of the engine...
Suspect oil pump and or front main seal leak...?
Timing Cover...?
Cylinder head cover...?
Distributor shaft housing seal...?
puffin04
07-10-2015 09:17 PM
noahstancik
07-10-2015 11:18 AM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Engine running rough
