Engine running rough
I have a 1990 truck with 22re engine. It will idle but a little rough when cold. With WOT the engine revs up and then right back down. It does this the whole time with WOT. Anyone know what I should do? Thanks
When I open throttle all the way open its revs up then back to idle and continues to do it while the throttle stays completely open. I did take intake hose off and it is covered with dirt and grime. What can I clean it with?
Got cleaner today and sprayed in and cleaned it out but still ran the same way. So I pulled plug off of the TPS and cleaned it. To my surprise it fixed my problem. Thanks for your help. Now I have to figure out where the oil leak is. Slinging oil all over the front of engine.
Jnkml
Jul 6, 2015 01:20 PM
Glad you found your problem.
