engine replacement, timing off....
Old Jul 14, 2008 | 02:33 PM
ddwyer's Avatar
theory #1: coolant temp sensor: possible, I did not change this from the old engine to the new one. Where is it?
theory #2: idle screw: unlikely, since both the old and new TBs exhibit the same problem.
theory #3: EGR valve: possible, Is the EGR valve the very simple ball-in-tube valve that inserts into the top of the valve cover? If so, I installed a new one. If not, where is it?
Old Jul 15, 2008 | 03:52 PM
ddwyer's Avatar
I swapped both sensors on the front of the intake manifold (green connector and black connector) from the original engine into the new one. The problem persists. I think at least one these is the coolant temp sensor, so I think we can rule that option out.
Perhaps EGR is the cause. I need to figure out where it is and swap it between the engines.
Old Aug 12, 2008 | 01:03 PM
sincal's Avatar
your egr valve is in the back of your engine, next to your firewall. Looks like a spaceship.
Old Aug 12, 2008 | 03:03 PM
abecedarian's Avatar
Both sensors are coolant temp sensors- one for the ECU and the other for the cold start circuit.
I keep reading along the lines of "cold started in the morning and was fine".
The idle and timing both need set when the engine is at normal operating temp / warmed up, not on a cold engine.
Honestly, it doesn't make a big difference how it idles when cold because that is a different operating state that depends on how the engine operates when warm.
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
saphirekosmos
Jun 22, 2015 10:26 AM
TheManOutside
Jun 18, 2015 03:32 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
