Engine Rattle? Video
Old Jun 12, 2010 | 01:37 PM
dhall50's Avatar
What does this sound like to you? Seems to go away when throttle is pressed. Could this be a vacuum or exhaust leak? Timing chain is newer and looked good the other day when i checked it. Thanks. Sorry for the pictures.
VIDEO: http://www.youtube.com/watch?v=FDE8YoHHCNs
Old Jun 12, 2010 | 01:51 PM
pruney81's Avatar
sounds like normal 22re valve train/injector tick to me. Your motor sounds pretty good actually for a 22re in my opinion
Old Jun 12, 2010 | 02:06 PM
85toy's Avatar
its a 22r, there are no injectors.
thats how my old 22r sounded, i think its just valve noise, you could adjust your valves and it might quiet down a bit.
Old Jun 12, 2010 | 02:07 PM
MaK92-4RnR's Avatar
its a 22r... thats how they ALL sound.
Old Jun 12, 2010 | 04:13 PM
dhall50's Avatar
Well it is kind of intermittent and I have adjusted the valves twice but if you guys think it sounds just fine then that's great!!
Old Jun 12, 2010 | 04:14 PM
MaK92-4RnR's Avatar
yeah... all 22r and 22res sound the same... the valves and injectors ( if its an RE ) all knock and tick. came factory that way
Old Jun 12, 2010 | 04:31 PM
T_F_E's Avatar
That exactly how mine sounds too and I was getting worried, thats good to hear!
Old Jun 13, 2010 | 09:31 AM
ohgood's Avatar
i haven't heard one like that unless something was wrong inside...
valve cover too tight, valve adjustment needed, wrist pin worn... etc
sounds like it's up top from the video.
for comparison, my 22r w 184,000 miles, cycling AC:
[YOUTUBE]http://www.youtube.com/watch?v=0G3oJtjng9A[/YOUTUBE]
there is a link for HD video at that, better sound anyway.
Old Jun 13, 2010 | 09:54 AM
flecker's Avatar
From: White Mountains, Arizona (Yes it does snow in AZ)
Look, it's an old rig and NEW to you. YES, po the cover and check valve lash and it's kinda hard to arm chair quarterback from here with a video but snug the exhaust manifold to 35 ft lb. with a torque wrench because it sounds like a combo of valves and exhaust leak tick to me.
BOTH OF THESE ARE FREE- except for your time.
BTW- the mechanical fuel pumps rattle on these as well.... even the NEW ones. so don't get excited by that.
Rule those out and then take care of that pulley bearing on the tensioner
HOW? take belts of, spin tensioner puley and listen for sound that isn't smooth. If it's SMOOTH- leave it.
Old Jun 13, 2010 | 10:08 AM
PismoJoe's Avatar
Maybe I'm "high" but it looks like your driver's side chain guide is broken at the top part, and the chain is wearing into your head from those pics you posted.....
Old Jun 13, 2010 | 10:16 AM
flecker's Avatar
Yeah... put the weed down maaan.
I see the guide and looks fine to me.
Old Jun 13, 2010 | 10:17 AM
PismoJoe's Avatar
Really? I thought that the drivers side guide was taller than the passenger side one? Do you not see those marks on the side of the head
Old Jun 13, 2010 | 10:19 AM
flecker's Avatar
Yeah I see them.... thats when the old guides broke and rubbed for a bit. the ones on there now look normal to me. The chain wouldn't be able to make those marks where they are with the guide s he has now.
He might have lost a little piece but look at pic #1- theres no way his chain is gonna go there...
Old Jun 13, 2010 | 10:22 AM
PismoJoe's Avatar
Ohhhh old guides, no body tells me nothin! I thought I was crazy ha a chain definitely made contact with the head at some point lol
Old Jun 13, 2010 | 10:25 AM
flecker's Avatar
Oh yeah the chain definately made contact at some point! those marks are a tell tale sign of that....
The ones in there now though are fine. lol... I confuse, when.... shoot. Lost my train of thought.
Lolers'
Old Jun 13, 2010 | 10:30 AM
PismoJoe's Avatar
Haha ok, back on track....
Yes, nice sounding 22R you got there, dhall!
Old Jun 13, 2010 | 10:36 AM
flecker's Avatar
Didn't see that you adusted the valves already.... Take a hard look at exhaust leak next. DO NOT over-torque the nuts! Just to 35 ft. pounds then STOP... might need a new gasket and use some copper high temp sealant when you re-install.
After install, warm up ad re-torque ONCE. Then see how it rolls.
Old Jun 13, 2010 | 11:38 AM
dhall50's Avatar
Yeah, probably an exhaust leak. I just recently replaced a head gasket and the two rear exhaust bolts were stripped and not torquing properly i fixed it but i think the gasket was already messed up at that point. Thanks for the input guys! Ill get around to fixing it in a week or two.
Old Jun 16, 2010 | 04:39 PM
dhall50's Avatar
I still need to re do the exhaust gaskets but I can not feel a leak anywhere. Re checked the valves again and they were all spot on. I also made sure the valve cover was not overtightened and while this helped a little I dont think it affected the particular noise I am trying to fix. Local stores want a ton of money for the exhaust gaskets.
I already forgot but does my year of truck have the circle exhaust ports or pear shaped?
Old Jun 16, 2010 | 04:48 PM
FieroGTdude's Avatar
Sounds normal to me. But you can check the valve cover and make sure its not to tight, if your worried about it. Just turn the radio up and drive it.
