Engine Rattle? Video
Old Jun 18, 2010 | 08:31 AM
dhall50's Avatar
Originally Posted by FieroGTdude
Sounds normal to me. But you can check the valve cover and make sure its not to tight, if your worried about it. Just turn the radio up and drive it.
Only does it at idle so i don't hear it when under way. I took it for a long drive up in the hills yesterday and the noise was completely gone! Nice and quiet motor. I must have to really heat it up for the sound to go away so ill just leave it be. Things must be expanding to within their normal ranges.
Old Jun 18, 2010 | 01:20 PM
FieroGTdude's Avatar
If it goes away when it warms up i would check the valve clearance, if you havent allready.
Old Jun 24, 2010 | 05:18 PM
dhall50's Avatar
Updated video. Valves adjusted several times even tighter with no help. Exhaust fixed also. Maybe my idle is just too low..Webber carb...
http://www.youtube.com/watch?feature...%2FtfEnagS9HSY
Old Jun 24, 2010 | 05:43 PM
flecker's Avatar
From: White Mountains, Arizona (Yes it does snow in AZ)
You know you got a big ol vacuum leak in your valve cover right?
That port at the front has a hose connected to the Carb base typically, unless you plugged it or something. You can get a cheap breather for it from any auto parts store. Tha may be part of your problem'o
Old Jun 24, 2010 | 06:08 PM
  #25
dhall50's Avatar
It only connects to the air filter.
Old Jul 9, 2010 | 11:52 PM
  #26
dhall50's Avatar
If I am missing a small chunk off the top of the guide it goes to the oil pan right? Are these hard to remove? I am wondering if I should pull the pan and check for old parts lol. Just thinking it might be hard to seal the pan again.
Old Jul 11, 2010 | 09:44 PM
  #27
nick66's Avatar
Don't wanna steal the thread but it's better then making a new one, my 3vze makes the exact same noise, I guessed it was my valves but is it also a common problem for the v6? It also seems to be a lot louder from the left side (looking from the front of the car)
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
