Engine quits when put in D or 4L
Old Jan 9, 2021 | 11:55 AM
sherpapilot's Avatar
Hello fellas...
I am baffled by this one. 1992 4Runner V6, automatic, 4WD
Engine starts with no issues. When I shift to “D” engine quits instantly, injectors stay engaged. Go back to “P” I can get the engine started but I can tell fuel was dumping in.
Same exact scenario happens again...shifter in “P” if I shift the transfer case into 4L....engine quits instantly.
I could not find a thread on this, so forgive me if this has been ask or discussed before.
What do you guys think?
Thanks in advance.
Old Jan 10, 2021 | 02:36 PM
SideSwipe's Avatar
What about other gears? Reverse do any better? sounds like a load issue. Fuel pump is triggered by AFM so when it dies it should also kill the pump as a safety measure not to flood the engine.
94yota111
Feb 15, 2012 08:02 PM
paxil4x4
Feb 26, 2007 01:18 PM
wishmaster22
13
Nov 18, 2005 04:35 AM
